Help with power steering lower banjo bolt driving me nuts.
Old 09-02-2015, 09:33 AM
lowpost99's Avatar
My high pressure power steering hose needs replacement and I can't seem to figure out how to get at the 24mm banjo bolt for the bottom. Underneath the exhaust blocks me, and neither fenderwell gives me any clearance for a breaker bar...let alone access to the nut....is this one that requires something like a crows foot?
any suggestions much appreciated.
Banjo bolt under and behind metal line...
lowpost99 is offline
Old 09-02-2015, 04:13 PM
vernk's Avatar
impact with a swivel extension
vernk is offline
Old 09-03-2015, 04:00 PM
lowpost99's Avatar
Like this?
Is this what I need? Plus an extension?
Old 09-03-2015, 07:05 PM
vernk's Avatar
yea something like that but be sure it will be short enough to clear the flex pipe, I think harbor fright has some that are just the swivel part that. you might be able to use a wrench on it also while using a bigger wrench for leverage..... yay for you tube I don't have to try and explain how to do it if you didn't know...... if you have a 12 point box end you should be able to get it into a position to be able to do it
vernk is offline
Old 09-04-2015, 04:49 PM
lowpost99's Avatar
Sucess!
Vernk.....you da dude as always.... I got it off easily with this from below...
24mm swivel socket and extention on the impact wrench...
Old 02-08-2021, 11:26 AM
DPenfield's Avatar
What about removing this because I have been turning with a 24 and I'm not getting anywhere how am I supposed to pull this thing off of this bracket is it our pen or something that's keeping it in place because I took out my power steering pump but it still attached to the banjo bolt I can't get off
DPenfield is offline
Old 02-08-2021, 10:46 PM
CMax03's Avatar
See the 5th and 6th gen sections....
CMax03 is offline
Old 05-16-2021, 11:18 AM
CMax03's Avatar
Yes with a long extension....
CMax03 is offline
Tragz
10-07-2015 05:31 PM
0scar214
05-20-2014 10:39 AM
CapedCadaver
28
04-01-2011 08:54 AM
KWheelzSB
05-25-2004 10:16 AM
rsemwal
01-16-2003 06:09 PM
Quick Reply: Help with power steering lower banjo bolt driving me nuts.
