2nd Gen not starting, error code 23 + 45
Hey guys, long time lurker, first time poster. I have a 86 Maxima with just a hair over 120k miles on it that does not want to start anymore. The car has sat fro about 7-8 months since it stopped working because I havent had time to work on it but now I have some spare time and I would like to get back to troubleshooting this car and getting it back on the road. When I pulled the error codes from the ECU I am getting codes 23 and 45.
I believe 45 has to do with the fuel pump starting to go out on the car, and I have ordered a new one along with the entire in tank sending unit assembly. I plan on replacing the fuel filter at the same time just because I dont know when it was done last and its an extra $10.
Code 23 looks like it has to do with the TPS. Just wondering if this is correct and if there is any way to verify it is bad before I just order one.
Thanks in advance!
David M
Thanks in advance!
David M
Thanks in advance!
David M
Thanks in advance!
David M
secondly....dont replace the fuel pump right away. the fuel pump code almost never comes on when the pump is "failing". the ECU monitors the electrical circuit only so it only throws that code if there is an open or short in the circuit. so before you replace pump, pull up the back seat and use a voltmeter to see if the pump is getting 12 volts for about 3 seconds after the key is turned(priming). if it is, its a bad pump. if it isnt, then check the fuel pump relay next. thats most likely youre no-start cause.
diagnostics must be carried out before repairs or you waste a lot of time and money. promise.
The the fuel pump was completely dead. Used a voltmeter and was getting 12v to the pump. I pulled it out and ran 12v to it and got no noise out of it at all. A new Bosch was only $99 for the entire assembly so no big deal. My fill arm was seized so its nice to be able to see fuel levels again.
Also RockAuto had a TPS for $23 shipped. Already ordered it and it arrived today. Swapped it in and the car started right up. Its running a little rough still, but i think with a new set of plugs and wires along with an oil change and new air filter it will be back on the road again.
Thanks for the reply
Sam Maxima
02-24-2016 05:52 AM
cardana24
02-12-2016 09:45 AM
max95q
03-29-2015 08:57 AM
jnm2kse
08-29-2000 06:55 AM
