Torque specs.
Old 06-28-2010, 07:39 PM
7mJoe's Avatar
Torque specs.
I need to know the torque specs for the VG flywheel, the pressure plate, and axle nuts. I have the specs but I'm not sure if they're right
flywheel
61-69ft lbs
Axle lock nut
174-231ft lbs
Pressure plate
25-33ft lbs
Lemme know what you guys thinks.
7mJoe is offline
Old 06-28-2010, 07:47 PM
STFU n00b!
Matt93SE's Avatar
Looks about right to me. be sure to torque the wheel bearings to the max of that spec. go too low and they have a tendency to come loose and eat wheel bearings.
1. search on here for FSM link.
2. download FSM.
3. open to appropriate section and find specs for yourself.
4. work on car with full confidence in your work.
Matt93SE is offline
Old 06-28-2010, 11:29 PM
Call me Wookiee Goldberg
CapedCadaver's Avatar
2. download FSM.
one small problem.
the only FSM for 3rd gens online is a 94. which has torque specs for a VE flywheel with 8 bolts, but not a VG flywheel with 6 bolts, since all the 92-94 VGs were automatics.
CapedCadaver is offline
Old 06-28-2010, 11:53 PM
7mJoe's Avatar
Yea, I had an fsm but it didn't look right. I just wanted to verify before I took it down the road and right back to square one! I'll be done tomorrow! I'll let you guys know how it turns out!
7mJoe is offline
Old 06-28-2010, 11:58 PM
maximo018's Avatar
The FSM I have has both VE & VG from 89-94.
maximo018 is offline
Old 06-29-2010, 12:25 AM
the FSM goes one year at a time.. the only PDF out there for 3rd gens is the 94. 4th gen and newer has all years, but not 3rd gens.
www.nicoclub.com/FSM/maxima
unless you have something nobody else does, then what you saw for the VG was the a/t flexplate, not the m/t flywheel.
however since the VE uses the same spec for the a/t or m/t, it's safe to assume the VG does the same thing. which evidently is 61-69 no matter what.
Old 06-29-2010, 12:30 AM
maximo018's Avatar
Ah I finally found it. yes 94.
Old 06-29-2010, 07:35 AM
STFU n00b!
Matt93SE's Avatar
<---------- read that, n00b.
there's no problem. The torque specs are the same.
one small problem.
Matt93SE is offline
Old 06-29-2010, 12:06 PM
7mJoe's Avatar
Who you talkin to bro? I got it all right, but I ran into a problem.
7mJoe is offline
Old 06-29-2010, 12:47 PM
STFU n00b!
Matt93SE's Avatar
Who did I quote in the reply, BRO?
Matt93SE is offline
Old 06-29-2010, 04:04 PM
maximagician's Avatar
i bought my fsm for my old white 92 gxe like 10 years ago
the 92 fsm has vg and ve sections and its thick as a phone book
maximagician is offline
Old 06-29-2010, 09:06 PM
Hatmanafro's Avatar
ouuuch.. haha
Hatmanafro is offline
Old 06-30-2010, 02:04 AM
ColombianMax's Avatar
relax brahs we're all in spec now brahs
ColombianMax is offline
Old 06-30-2010, 08:55 AM
i noticed that after the fact, o Captain my Captain
for some reason i thought i had seen them listed as being different in the past.. not sure why. or maybe i assumed that 8 bolts would need less tq-per-bolt than 6.
Old 06-30-2010, 11:19 PM
bigmax90's Avatar
You said it bruh!..lets keep it kosher!
bigmax90 is offline
Old 07-01-2010, 12:24 AM
7mJoe's Avatar
Bros, I got it running. Everything went well. I torqued the axle nut to 220. Think that will be enough? Sadly, one of the axle seals is leaking $100 worth of transmission fluid out. Gotta get that fixed! Thanks for the help gang!
7mJoe is offline
03-12-2020 12:06 AM
thatcollegestudent
18
10-05-2015 02:29 PM
The Wizard
24
10-01-2015 08:47 PM
dcam0326
09-18-2015 04:52 PM
Quick Reply: Torque specs.
