Need injectors but which ones?
Old 07-09-2013, 01:58 PM
TonyJr's Avatar
Which injectors would fit my ve for a turbo setup?i have no idea, where to start since there barely any info for a ve setup.
TonyJr is offline
Old 01-23-2015, 10:27 AM
TonyJr's Avatar
Is it the 94 95 96 300xz tt injectors?
Or 1995, 1996
TonyJr is offline
Old 01-23-2015, 10:38 AM
akurtzer57's Avatar
I have a set tt injectors in vg rail if your interested.
akurtzer57 is offline
Old 01-23-2015, 01:01 PM
TonyJr's Avatar
I have a 1992 se ve30de. I don't think it would fit
TonyJr is offline
Old 01-23-2015, 01:20 PM
Ad·min·is·tra·tor
DanNY's Avatar
take a pic of the connector on your injectors
DanNY is offline
Old 01-23-2015, 01:26 PM
2 VE's are better than one!
James92SE's Avatar
You want the "new style" injectors. So if you're specifically ordering for/from a TTZ, you want 95 or 96 TTZ. However, the non-turbos used the "new style" injectors on 93+
You don't need to be searching for VE specific stuff. Just search for the 95/96 z32 TTZ stuff. Even SR20DET stuff. All the same injectors. Your deciding factor should be the CC though
James92SE is offline
Old 01-23-2015, 01:32 PM
TonyJr's Avatar
I'm looking for 300hp and I learned that 370cc was enough. I figure it is 1995-96 , that sucks because I just found 1994 300zx tt injectors with fuel rail for $175.
So I'll start to look for sr20det injectors as well. Thanks for the info.
But 300hp is my goal.
James how's your turbo setup doing?
TonyJr is offline
Old 01-23-2015, 01:42 PM
akurtzer57's Avatar
370cc will be enough for 300hp. The q45 also used 370cc but unsure if there new style or old.
Old 01-23-2015, 02:38 PM
CS_AR's Avatar
The Q45 switched from Phase I (old) to Phase II (new) with the 94 model year. There may be a few late 93 models with Phase II injectors, but I've not seen any at this point.
Deatschwerks in OKC sells a kit that allows Phase II injectors to be used with Phase I rails. The Phase II injectors are reported to last longer than the Phase I injectors.
I use BWD Black Dot Phase II 370cc injectors in my 91 Q45 with the Deachwerks kit.
You can see the Phase II pintle caps in the rails below.
Q45 rails came nickle plated from the factory. As part of a rail restoration project, I sent the rails to a plating company in Memphis TN that has an electroless plating process that plated the rails on the inside as well as the outside. Nickle plating fuel system components is a technique used in Brazil for cars that run on ethanol.
CS_AR is offline
Old 01-23-2015, 04:44 PM
James92SE's Avatar
Setup is fine but the engine has bad rings and smokes like a ****. I have a brand new rebuilt VE to stick in it just haven't gotten around to it since I've been overhauling my Civic. Finally finished my Civic last weekend and got it out of the garage so I was able to pull the turbo car in so this is where she stands now waiting for the swap and some downpipe modifications
Old 01-23-2015, 06:22 PM
TonyJr's Avatar
You using a gt35 right?
Did you ever finish nistune tune?
TonyJr is offline
Old 01-23-2015, 06:28 PM
akurtzer57's Avatar
Can't wait get my setup finished.
Old 01-23-2015, 07:50 PM
James92SE's Avatar
No I don't have a GT35
It's been tuned by Bryce at Alamo Autosports here in DFW but he had never used Nistune before and was fairly critical of Nistune once he started messing with it and had a hard time with it, so I have never been totally 100% confident in the tune
Old 01-23-2015, 07:58 PM
akurtzer57's Avatar
James when you get your motor in feel free email me your tune with a data log. I can look it over.
Old 01-23-2015, 08:31 PM
CMax03's Avatar
Nice lift!
CMax03 is offline
Old 01-24-2015, 01:12 AM
TonyJr's Avatar
It's good to see some 3rd gen turbo. Me n another 3rd gen are working on our ve turbo setup in Orlando fl. Pics coming soon
TonyJr is offline
Old 01-24-2015, 08:06 AM
James92SE's Avatar
Is the other VE guy on the Org?
Old 01-24-2015, 09:57 AM
TonyJr's Avatar
Yea
TonyJr is offline
Old 01-24-2015, 12:10 PM
Tiniform's Avatar
Surprise to hear that. I saw your car once tony, but haven't senna other "fixed-up" ones..surprise to hear you say there is another that's being modded. Except for 2005 max rims, mine is pretty much stock. Went off track a bit......
Tiniform is offline
Old 01-24-2015, 02:43 PM
James92SE's Avatar
Yea
Lol I guess I should have clarified. Who is the other member? Or is it a secret
Old 01-24-2015, 07:14 PM
TonyJr's Avatar
His name is jeff but I cant remember his user name lol
TonyJr is offline
Old 01-24-2015, 07:45 PM
akurtzer57's Avatar
My name is jeff...
Old 01-24-2015, 08:05 PM
Fakie J Farkerton's Avatar
My name is jeff...
I see what you did there.
Fakie J Farkerton is offline
Old 01-24-2015, 09:49 PM
TonyJr's Avatar
Lol
TonyJr is offline
Old 01-25-2015, 10:04 AM
CMax03's Avatar
There are formulas that are used to estimate the amount of fuel needed depending on your redline, boost level, turbo size and engine size...
CMax03 is offline
Old 01-25-2015, 10:21 AM
akurtzer57's Avatar
Tony check out twinturbo.net goi d chance find some there.
Old 01-26-2015, 11:34 AM
TonyJr's Avatar
On my way to check on a 1994 q45 to see if it still has its injectors. If it does, is cost me only $20. Wish me luck.
TonyJr is offline
Old 01-26-2015, 11:41 AM
James92SE's Avatar
Is it at a you-pull-it junkyard? If so, shouldn't cost you anything
Old 01-26-2015, 12:01 PM
CS_AR's Avatar
Here's the underside of the Q45 intake plenum. Note the rubber hoses that will need to be released to access the injector rails.
Slideshow.
http://s286.photobucket.com/user/Rid...m/Under?sort=4
CS_AR is offline
TonyJr's Avatar
It is but I'm trying to look like a good guy on the forum lol. 5 finger discount
TonyJr is offline
Old 01-27-2015, 07:25 AM
Ad·min·is·tra·tor
DanNY's Avatar
why actually sit there and do the calculation...it's da innerwebs...they just ask ppl on the fore-am's and get their answers spoon fed to them.
DanNY is offline
Old 01-27-2015, 07:30 AM
Ad·min·is·tra·tor
DanNY's Avatar
My name is jeff...
DanNY is offline
Old 01-27-2015, 11:26 AM
TonyJr's Avatar
They use the cfm calculator to figure which turbo is best. But that's to much work for me. I planned on getting a gt35r. Ive learned anything bogey then 70ar is good for ve. High end power spool.
TonyJr is offline
Old 01-27-2015, 01:04 PM
Ad·min·is·tra·tor
DanNY's Avatar
so you're getting a GT35R that cost over a thousand dollars new (not the cheap POS chinese made one) and you're not willing to sit down for 10-15 minutes to do some type of calculation to make sure the AR and even if the turbo is correct for you? take a look at a turbo map before you buy it. do you know what type of flange are you going to go with? 4 bolt, v band, 5 bolt with internal WG, divided? how about compressor? with or without anti surge?
not trying to be a naysayer but this is recipe for disaster.
high end spool..but you don't want to be at 5000 RPM when your turbo is starting to come in on boost...right? because then you'll hit redline just when that turbo is starting to spool up.
turbo map explained...
this is a GT35R 70AR..figure out where are you on this map.
DanNY is offline
Old 01-27-2015, 01:09 PM
TonyJr's Avatar
Cool thanks
TonyJr is offline
Old 01-27-2015, 02:07 PM
James92SE's Avatar
Danny pretty much hit the nail on the head
I never did any fancy calculations but my car is .63 A/R and my boost already comes on a tad later than I would like. I want to say I'm close to 4500 RPM full boost in mine. I couldn't imagine not getting full boost till 5k or something.
Old 01-27-2015, 04:51 PM
madmax123's Avatar
Originally Posted by tonyjr
his name is jeff but i cant remember his user name lol
madmax123
madmax123 is offline
Old 01-27-2015, 07:48 PM
madmax123's Avatar
James92 how did you end up setting your pcv system
Old 01-28-2015, 01:35 AM
TonyJr's Avatar
Originally Posted by madmax123
madmax123
Lol hey jeff. Looking for turbo n figuring out what I'm going to use for tuning. I'll be ready then top start the labor
TonyJr is offline
Old 01-28-2015, 07:58 AM
Ad·min·is·tra·tor
DanNY's Avatar
what size is your turbo James?
DanNY is offline
Quick Reply: Need injectors but which ones?
