shudder in reverse
gotta know if its a 5spd or automatic. 5spd, youre probably not giving it enough throttle and its shuttering. automatic, check for vacuum leaks in the engine bay. vacuum leak can make it want to stall in reverse
Is one of the lights staying lit on the comfort and power mode switch beside your shifter? You could check to see if the tcm has any codes. I can't remember off the top of my head how to check but there is a write up on it if you search. I didn't have any codes on mine but i tried it anyway and it does work. You just have to read the flash codes like the diagnostic for the ecm. Search for the write up and see if you have any codes?
James92SE
142
01-02-2024 09:23 AM
lrb6805
09-17-2015 04:49 PM
