battery draining while car is off
went to start car and needed a jump. battery was low, not dead. jumped car and drove for about 45 minutes. restarted car no problem. parked car, came back around 3 hours later. battery completely dead, no lights, couldn't even use the keypad.
been having trouble with the rear window. won't stay up. while driving the car that day the window goes down by itself. it won't go back up.
jump the car and drive home. restart the car no problem. next morning battery completely dead. take car to walmart and they give me a new battery for free.
just went to start car this morning and battery completely dead.
made sure nothing was left on.
could the window somehow be draining the battery even when the car is off.
any other suggestions?
Check your headlight switch. In my Maxima, and another one's in my neighborhood, had a headlight switch issue. When the car is off, there a short that causes the highbeam (for our driver's side) to turn on, although the switch is in low beam.
Put the switch in high beam mode, with the lights in off, before you walk away, could that be your problem?
... good indicator it's that, is your brake lights are on with car off and no one in it.
Harbor Freight sells "short testers" that simply plug into your fuse box. Remove a fuse and plug it in, it will tell you if there is a short/drain on that circuit. They run about $10.
Just hit me...have you removed the battery to see if it drains on it's own? It could be a bad battery that's just dying after sitting. Very common issue - may not be electric related at all.
Lakersallday24
06-16-2019 01:35 AM
altome15
08-10-2015 07:05 PM
erniel
08-08-2015 09:32 AM
