WHERES THE interior door light fuse?
Old 08-10-2003, 04:15 PM
dgpfx's Avatar
i was changing the bulb on the drivers side door and it stopped working... I think it was the fuse that blew, anybody know where that fuse is...
I cant find it..
dgpfx is offline
Old 08-10-2003, 04:27 PM
Master Will
metallic97gxe's Avatar
when you leave the doors open for long periods of time they go off try closing the doors and see if they come back on I don't think a fuse is blown..
metallic97gxe is offline
Old 08-10-2003, 04:57 PM
dgpfx's Avatar
no its not that...
i know they turn off when you close the door and turn on when you open the doors.. and after a long period it turns offf. But the passengers side works.. mine doesnt even turn on...
dgpfx is offline
Old 08-10-2003, 05:03 PM
Kevlo for President
Kevlo911's Avatar
sounds like a bad bulb if the passenger side door light works
Kevlo911 is offline
Old 08-10-2003, 05:42 PM
dgpfx's Avatar
awwwwwwww man. its the fuse.. i tried like 5 bulbs
dgpfx is offline
Old 08-10-2003, 06:09 PM
MIXXMAX's Avatar
If I can remember correctly (because I don't have my '95 anymore), the fuse is marked "int. ill" on fuse box cover. The fuse is a 7.5 amp fuse located on the top middle row in the fuse box. Keep pulling fuses, until the interior lights go out. Once you find the fuse, and it appears OK, then you might have a problem with that particular door that doesn't work right. You may have a problem with your Body Control Module.
MIXXMAX is offline
Old 08-10-2003, 06:54 PM
Ramius83
Nope, I have the same problem on my 96. My driver's side door lamp has quite working. I have tried over 6 different bulbs with no luck. I am gonna take my multimeter to it one of these days, after I get done with my current project. If worse comes to worse, I will just have to trace down the wires and patch/rewire new wires......
Old 08-10-2003, 07:11 PM
Maxtank's Avatar
i'm having the same prob with the passenger door. Multimeter showed nothing. I'm gonna dig deeper, I know in the door itslef there is no inline fuse, i'm thinking maybe within the dash, i'm gonna check the door switch see if theres something in there
Maxtank is offline
Old 08-10-2003, 07:21 PM
dgpfx's Avatar
!!!!!! its that hard.. man....
its retarded.. All i did was change the bulb...?
wuuuut! can i splice the wire from the other door,, rewire it and run it to the (drive door)
dgpfx is offline
Old 08-10-2003, 07:59 PM
あおい A32
bluA32's Avatar
maybe u tapped the metal piece with a screwdriver n the light stopped workin...
change ure driver's door window switches...if u wanna check if that's the problem..borrow someones window switch and plug it in..pop in the bulb n see if it works first..den go junkyard n get one =)
bluA32 is offline
Old 08-10-2003, 09:17 PM
Maxtank's Avatar
if that fuse was blown none of the interior lights would work
Maxtank is offline
Old 07-04-2015, 03:09 PM
bigd480's Avatar
Forgive me for bumping an 11-year-old post, but I'm having the exact same issue and rather than rehashing the same things that didn't work for OP, I was wondering if anyone knew what the fix to this issue was?
When I ground the bulb to a bolt, the bulb lights up faintly. The housing seems to be pretty much all plastic, so I didn't think it was getting ground from anything but one of the two wires. Tried the fuse, all other interior lights work, al other door electronics work (DS door). I get like 47mv when probing 2 contacts with multimeter without grounding to a bolt (which gets 12v on red wire).
bigd480 is offline
Old 07-04-2015, 09:25 PM
Junebug1701's Avatar
The courtesy light on the driver's door is powered by the window switch panel, believe it or not. The other day I removed the door panel and was surprised to see that the light didn't come on until I plugged the window switch panel back in. There is supposedly a CPU in that panel, and a short at the lamp can blow it out. The only repair is to replace the whole panel.
Junebug1701 is offline
Old 07-05-2015, 07:36 AM
Daniel VQ30life's Avatar
yea, rain water over time tends to blow em
Daniel VQ30life is offline
King_Ten_Ahead
09-30-2015 04:27 PM
vrajesh123
08-31-2015 11:00 AM
rbaker100
08-28-2015 08:11 PM
Jeffesernia11
08-23-2015 06:09 PM
kjm900r
08-05-2015 07:14 AM
Quick Reply: WHERES THE interior door light fuse?
