EVAP canister purge volume control valve??
Old 08-16-2007, 05:39 PM
  #41
jteer1971's Avatar
Our code was P0443...Will that be the correct part for that code?
jteer1971 is offline
Old 08-22-2007, 06:27 PM
  #42
chasMAX's Avatar
Jteer1971...pull the connector plug from your ECPVC as shown in the great pics above and check the pins ON THE VALVE as suggested using an ohm-meter. I imagine you'll find that it's faulty considering the code you have.
Shell...where did you end up buying one instead of the Stealership?
chasMAX is offline
Old 08-23-2007, 12:17 PM
  #43
Graem's Avatar
Originally Posted by sterling99SEL
Just after replacing my knock sensor, I'm getting these three EVAP-related codes:
Is it likely I could have damaged my EVAP control valve or knocked a harness loose possibly?
Yes, you most likely unplugged the harness to get at your knock sensor and did not put it on properly. Thats exactly what i did and after clipping in the harness i lost my ecu codes
Graem is offline
Old 03-11-2009, 12:05 AM
  #44
C-ko's Avatar
i've had this exact same problem with the EVAP Purge Volume Control Valve. In the pics in the previous page, is the evap purge volume control valve the metal part or the plastic part?
C-ko is offline
Old 03-11-2009, 12:38 AM
  #45
No more Maximas...
pmohr's Avatar
Did you not read his post? It's the entire thing.
Bumping a 2 year old thread for not reading, and after you already got your answer in the newbie thread
pmohr is offline
Old 12-21-2009, 06:09 AM
  #46
bebekhijau's Avatar
will this canister can be used forever or how will i know it should be replaced?
bebekhijau is offline
Old 12-21-2009, 08:44 AM
  #47
cashoit's Avatar
the canister and the valve are too differnent things.
I had this issue and it was cuz the wire harness fo rthe valve was all corroded and and new wires needed to be connected.
I wd say these thing last forever. jus trace the wires to see if there is a short. Or check the FSM for troubelshooting
cashoit is offline
tseng1023
10-15-2015 08:30 AM
hayne
10-05-2015 11:53 AM
msellas
09-23-2015 09:16 PM
dcam0326
09-07-2015 07:26 AM
Quick Reply: EVAP canister purge volume control valve??
