car jerks while driving + loss of power
#41
I would definitely not buy any 02 sensors from anywhere other than the dealership. If you do definitely don't buy the splice-in type. As for everybody else on here I read a service bulletin about water coming off the a/c condenser in our year cars this leak was causing water damage to the ecu, and the problems that came from this water damage were said to be jerking and power surges. The dealerhips started selling ecus with shields to prevent the water damage.
#43
i just had the dealership do a 27 points in my max...and what came out is onlye the knock sensor
now i have about 5 different choices + buy it from the dealership.
Which one would you guys recomend?
Echlin Ignition Detonation ''Knock'' Sensor ($169.00 +tax) Napa (dont know)
WELLS KNOCK SENSOR ($169.99 + tax) Autozone (3 months warranty)
Niehoff Ignition WA1711 Detonation (Knock) Sensor: ($269.99 + tax ) Advance Auto parts. (1 yr warranty)
Standard KS79 Knock sensor ($113.99 + tax) Advance Auto parts. (1 yr warranty)
Knock Sensor at Dealearship ($167.72 + tax)
Please reply your coments...
#45
goto www.jerryromenissan.com
oem knock sensors for $89 plus shipping
#48
someone at the autozone told me that about the 02 sensor...he said go under take it out spray it with carbcleaner and the problem will go away, he said is built up dirty on the down stream 02 sensor...
I'm replacing my knock sensor this weekend and i will take a look at the 02 sensor..
#50
#51
Bumpin old threads .....
Ima give you the benefit of the doubt and say u didnt see the thread start date
#52
check resistance of the coilpacks, if they(and the plugs) are good, replace fuel filter(I had a nasty problem with that) and run premium fuel. might also help to seafoam the car... That procedure is in the How-to sections.
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
yat70458
08-03-2015 01:16 PM
