Automatic Transmission problem, takes long to shift ??
Old 01-15-2006, 10:02 AM
chk34kk's Avatar
The car takes a long time to shift from first gear to second, and the rpms go up to about 3500, which is only in the first 10 minutes of driving the car. After the 10 minutes the problem stops. Also the other day, the car was locked into second gear and wouldnt swich at all, no difference when putting the car into 1st gear either. Please help !!
chk34kk is offline
Old 01-15-2006, 10:16 AM
Ridge Runner's Avatar
I'm not a transmission expert but I've had similar problems.
I believe locking in 2nd gear is a design feature, commonly known as "limp mode," allowing you to drive from whereever you are to a repair shop.
Problems I've had include:
- Clutch material starts to come apart, clogging up orifices. This requires taking apart the transmission, cleaning it, and replacing the torque converter assembly, I think.
- Valve body or control body valves stick. If you are very handy, this can be pulled out, disassembled, and cleaned.
Ridge Runner is offline
Old 01-15-2006, 10:20 AM
YoU CaNt SeE mE
Maxima-4DSC's Avatar
ive also heard about the TCM going into a fail safe mode but im no expert maybe someone can clarify
Maxima-4DSC is offline
Old 01-15-2006, 10:21 AM
s0ber's Avatar
Sound's like a rebuild or replace is near... Sorry to hear for your loss :\
s0ber is offline
Old 01-15-2006, 10:24 AM
YoU CaNt SeE mE
parts for the 4th gen are cheap ive seen rebuilts for ~500 to 750 as long as you swap the trannys in your driveway. ive seen engines for the same price range all thought used.
Old 01-15-2006, 02:54 PM
dot dot dot ...
NmexMAX's Avatar
Holy vague post Sunday...
Is it slipping?
NmexMAX is offline
Old 01-15-2006, 03:56 PM
FormorAccordMan's Avatar
well, I do know that it may take about 10 min, especially due to the cold for the TC to lock up. But in your case, it seems that you have some other serious problems. You are not refering to the usual slushbox auto that our car has, ie, not downshifting completely without coming to a full stop are you? IF these are the symptoms, then it is normal. If not, then you may have to get it checked out. good luck.
FormorAccordMan is offline
Old 01-15-2006, 04:29 PM
racin89lx's Avatar
i was having similar problems and had to get a rebuild. after a while it just wouldnt want to shift out of first until 3500 rpm's. on the highway it started slipping alot and that is when i decided it was time to get it fixed. it ended up being a bearing that failed due to nissan not allowing enough oil to get to it. the guy that rebuilt mine said he drilled a larger hole for the oil to go through and prevent the problem in the future. hopefully this isnt your problem but i would get it checked out to be safe.
racin89lx is offline
Old 01-15-2006, 09:30 PM
TehDago's Avatar
How often do you drain/replace your fluid and filter?
If it hasnt been done in some time it may be a good idea. If you havent been religious in the past about your fluid changes it may be a good idea to get a power flush done. Then wait a week and get the fluid drained and the filter replaced.
If you are lucky and it is just broken down fluid and not broken down friction materials then this may get you a few more miles. If the friction materials have begun to break down find a good shop for a rebuild.
TehDago is offline
Old 01-16-2006, 12:46 AM
Always sunny in philly
Nismotic's Avatar
My 2nd gear is slipping as well...you'll look forward to a rebuild soon.
Nismotic is offline
Old 01-16-2006, 11:18 AM
Sy0p's Avatar
man thats what happend to me 2wice im on my 3rd transmission. the second one was from the junkard and the guy didnt tell me it was.
Sy0p is offline
Old 01-17-2006, 05:45 PM
chk34kk's Avatar
The tranny isnt slipping, and the fluid has been changed recently, im at 93,000 miles. Tranny Rebuild ??
chk34kk is offline
Old 01-17-2006, 07:12 PM
DcMaN's Avatar
maybe the solenoids in the transmission. Im no tranny expert but i know good matinence + a tranny cooler will help savor the original transmission... I have a stage 2 VB with tranny cooler and flushed it every 15k im now on 180k with no signs of any problems *knocks on wood*
DcMaN is offline
Old 01-17-2006, 09:21 PM
KRRZ350's Avatar
Ditto, you should check the level and condition of the fluid first. Also, it sounds to me like worn bands, the classic symptom of these is that you have to ease off of the gas for it to upshift into the next gear.
KRRZ350 is offline
Old 01-17-2006, 09:24 PM
KRRZ350's Avatar
Oh and the limp mode on these cars puts it into 3rd gear. If you have a service manual, you can check the transmission codes via the overdrive light, but it is VERY tricky, the thing flashes so much so quick that it is next to impossible to tell the code.
KRRZ350 is offline
Old 01-18-2006, 07:19 AM
racin89lx's Avatar
hopefully its not needing a rebuild but if you are wondering about the miles i had just under 100,000 when mine had to be done.
Lakersallday24
03-20-2024 11:22 AM
CorollaULEV
30
08-09-2021 08:11 PM
cmpowell86
08-10-2015 12:35 AM
Gsantos79
08-08-2015 07:41 AM
Quick Reply: Automatic Transmission problem, takes long to shift ??
