NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
#443
Originally Posted by maximagasm
I have not heard you could put pre 99 coils on a 99. I'm assuming that since the coils tend to go out on a 99 and not earlier models that they are different.
#445
transmission noise question
well i have just had my clutch replaced about 2 weeks ago and before i had it done when i would turn on my car from cold start with the clutch not pressed in, you could hear like a kind of grinding noise while in N, then when i put it in gear and accelerate, the sound would go away but when i let go off the gas it would make a weird sort of grinding noise again on the de-cel. any ideas, the sound gets less noisy when its warmed up but its still there, espcially on 1st and 2nd gear de-cel. also i have recently started leaking trans fluid, but i think this could be fault of the mechanic that installed my clutch. well any idea's on what can be wrong with my trans?
#446
#448
Originally Posted by Cdg2125
Why not go back to the shop you had it done and have them look at it since it happened after they worked on it?
#451
Well I still havent ran the wires from mirror to the engine bay because im still hoping i find out an easier way.
but new issue, my fog light bracket for the right front foglight is broke, im not sure how, but i cant re attach the regular foglights im wondering if any one has installed a different kind of fog lights on a 95 or 96.
#452
I've been around for a little bit, but never posted...
got a question now,
i just installed GR2 in the max, i know they're not the best, but they don't completely suck, the car does not bounce at all, but if feels loose whenever i'm driving through curves or turns. I feel it looser in the rear end, any ideas???
got a question now,
#453
Under the radar
got a question now,
got a question now,
umm maybe they are too bouncy? thats why it feels loose in the turns? maybe, maybe not? What kind of loose are you talking about (like not all your bolts are tight and feels like its going to fall apart)?
#454
it feels like it moves horizontally, not too much tho, but enough for me to notice it.
my wife drove that suspension to the ground, i just installed these gr2s not too long ago, and then i started driving it, and i feel the looseness in the rear, i'll check the bolts through out the rear suspension see if any need tightning.
i just got done reading about a RSB, i don't think i will solve the problem but i think it may help...????
thanx once again
thanx once again
#457
Under the radar
Originally Posted by HEIGES
ok i have a 98 maxima SE what is the best thing to do to better my susspension and help the performance overall in my car. i just dont know exactly what to get that will help the most like SFC or RSB or what?
http://maxmods.dyndns.org/ this site is probably in this thread already but ill post it agian... this site IS GOLD!!!! use it, live it, love it!
I would say though get a strut bar, rear sway, and link up some tokico blues (I think those are the sturts that are close to stock just a bit stiffer.
#458
FDoT:
Is this issue re: your foglamp bracket? Have you looked into replacing just the bracket? You might have some luck finding some used in good condition here
www.car-part.com
or a new one at a decent price here:
www.courtesynissan.com
www.car-part.com
#459
clutch issue , help!!!
ok so i got a 96 max wit a stick , car was drivin fine today i went to work when i went to leave work there was absolutely no resistance on my clutch pedal. The car will not go into gear , i managed to force the shift to get it into first alittle and the car was movin jus so i could park the car , someone at work said its my pressure plate . i Have no experience with clutches at all , anyone have any ideas whats wrong???
#460
Interesting.............i pulled all the injectors out of my 99. 5 hanshins and a duralast like you get at autozone. Just got the car and it only has 70K miles, so apparently ALL SIX got replaced?
Originally Posted by KRRZ350
The pre-99 coils were made by hanshin, they switched manufacturers to mitsubushi for the '99's and those are the ones that are notorious for going bad, the hanshin coils rarely ever fail, the overall design never changed and you can intechange them just fine, they are nearly identical except for the name imprinted on them.
#462
Under the radar
I would say that your slave cylinder is bad. Easy/cheap fix. Or you could of lost all your fluid and have a leaking line... but my guess is the slave cylinder.
#463
#464
Originally Posted by FDoT
ok thanks and i swear on this site earlier i foudn a link to a sweet aftermarket and oem parts site i cannot for the life of me find it again tho.... i used to love custommaxima.com but there is nothing left for me to look for decent priced aftermarket/oem stuff....any links?!
Rockauto is like autozone butcheaper, courtesy is the ***** of nissan dealers for oem parts, and ebay is ebay
#466
is there anything like custommaxima anymore?
im looking for a site for a nice 95 maxima grille....and a site for black turnlights
#467
#469
i've been trying to check out the website but it won't even try to load up.
i'm really trying to find out about these SFC's, i have'em on my camaros and it's by far the best suspension mod. Are the SFC's weld on or bolt on??? and who makes them?
#470
#471
ok i have another question i have a 98 maxima SE, for suspension if i get the cattman suspension package and then some springs and struts will that make a big enough differance so that i dont need to get SFC's or should i still buy them?
#472
#473
the cattman suspension package is a coilover system. Why would you buy springs and struts after that? SFC will help your handling no matter what you are riding on. I don't think anyone said you need to buy SFC's, they are just very beneficial to the car's handling and ride actually.
#474
ok well then that just brings me to a ned perdicament, chould i get that cattman package or just go with some springs and struts if i am going to finish up with SFC's anyways?
#475
do ecu part numbers need to match??
i have a 1995 maxima. the ecu is bad. the part number is A18-B42-EL1. Can i replace it with any ecu from a 1995 maxima or does it have to be the exact part number in order for the motor to run? also, does the ecu in a 95 maxima control timing and ignition order?
#477
Any '95 fed spec will work, try car-part.com And yes, the ecu controls the ignition timing and firing order. Now, if you don't mind me asking, how do you know your ecu is bad? They are as bulletproof as the VQ30DE.........
#478
Glad you double checked, I don't know WHAT I was thinking when I typed that response, the beer might have influenced it a little though, sorry about that. You need to match '95, fed/cali spec emmisions and auto/manual trannsmission. Also, if your car is an automatic SE putting in a non SE '95 ecu will throw a code for the rear electronic engine mount.
#479
#480
Ok, I posted the other day about a tranny prob, I had added fluid/it was running worse. I worked on the ac too and got it working/hadnt been running it prior. So... the verdict is, the stalling I'm experiencing/rpms going up and down where caused BECAUSE I had the ac on, BECAUSE ... maybe the alternator is going out? It has a new battery. Doesn't seem to do it when I blast the radio too much but messes with me when I roll down my windows, also the belts squeeking. Anyone have any ideas?
-Atleast I think its the belt, it does it every rotation quietly/etc. But I was noticing problems with shifting a little/power steering firming up when letting off the gas and tightening when pushing down. Lights dimming as rpms lower... etc.
If anyone can narrow it down I'd be greatful.
