NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
#43
Originally Posted by allblackmax96
I searched around online to find an 00vi and couldnt really find one. would my best bet be going to a junkyard? does the 00vi mount on with no problems?
#44
when you take your oil pan (drain plug holder part) off and scrape the gasket off, is it supposed to be completely flat because four holes have a slight notch up and its the only 2 on each side and the top and bottom portion is fine, i think i need a new oil pan ill upload pictures tom if no one knows what im talking about.
#45
torque converter problems Help
i had my transmission rebuilt. i'm still having problems. i was told my solenoids went bad due to a bad torque converter. well my car is starting to act up again although not as bad, yet. the shop told me they put in bad solenoids so they will have to replace them. this is the second time they put in a bad part. it's either that or it is an electrical problem. so now i'm really doubting whether the TC needed replaced to begin with.
i can't find info on what happens to a car if the torque converter is bad. the problem i experienced was in drive the car/transmission would jerk really bad and it wasn't safe to drive. but in 2nd the car would run smoothly. if the TC was going bad would i still be able to drive my car in 2nd with no problem?
any help would be appreciated. i've been frustrated for about a month now.
#46
#47
#48
Originally Posted by Cdg2125
I don't know an exact answer to your question but I would recommend not going to this shop anymore. The fact you paid twice for them to but bad parts in baffles me. I don't know a shop that puts in bad parts and says, oh we'll fix it later. Make sure those are fixed first and see what happens.
#49
i put a lot of money into the rebuild cause i was told that's what it needed. as for the bad parts they put in, it's covered. i'm asking for the bad solenoids this time. i'm just not too knowledgeable when it comes to cars so i've been giving them the benefit of the doubt. but the more i deal with them the more doubtful i become. i don't know if they are charging me for parts i don't need, for stuff they didn't do to begin with or if indeed my luck is this bad. was hoping to get more info from here so i can not be so clueless. i figure i can be nice this one last time. anything else happens i will have it all looked into.
#50
Originally Posted by chaotic
I have owned a number of 3rd gens and currently own a vg5, which is a bit slow but very clean and reliable. I am looking at a '95 SE 5spd that needs work, I believe the current owner hit a pothole at a pretty high speed or maybe went over a median and bent a wheel, knocked it out of alignment and even blew both airbags. The car has 210k on it and is otherwise pretty clean. He is pretty firm on $1k and claims he will have the front suspension work taken care of and aligned at the shop he works at. I am thinking of picking it up and just removing the airbags and putting new covers on it. There is no inspection here and I have no intention of reselling it. Is it worth messing with and do you think the asking price is reasonable? I like the color combo and can fix it myself....
#51
Hey all,
My 99 sometimes performs better than others. I haven't been able to notice any specific pattern, but many times it just seems much 'peppier' than other times. I dont know of any factors that are directly related to the way it performs, though it seems to be a little sluggish on rainy/cold days.
I am gussing this is most likely an ignition problem, but im not sure what exactly I should look into. Could it just be plugs/wires, or something bigger like the coil? I have read a few places that 99 coils are a known issue...is this true?
#52
Can the SES light come on for no apparent reason? It came on today on my way to school. After my exam, I went home to extract the code(s) out of the Self Diagnosis ECU and it gave me nothing, no blinks. So I resetted the ECU and drove around for a while, and it didn't come back on...
Can the SES light be faulty itself? ...anything I should've done differently? or can do now?
---By the way, last I asked about wipers, and I was told to apply glass stripper to it to remove any old build-up of wax, etc, but when I went to Canadian Tire, they had absolutely no clue what it was. I looked through all their glass cleaning products and the most "deep cleaning" one (I assume) was something called "Invisible Glass" which claimed to leave no streaks, and so clean it'd be as if the glass was invisible... Is glass stripper just extra strong glass cleaner? Any brands / stores I should check out to get this stuff?
Thanks in advance!
Thanks in advance!
#53
Ok I got a question, yesterday I cleaned out my throttle body and all was good, today on my day to work i noticed the surging from 1.5-2.0 ks, it would only happen when I'm in neutral and Coasting, or when I'm at a complete stop, I have no codes so I have nothing to go On Now.
#54
Mod her. Ate her.
#55
Mod her. Ate her.
#56
Thanks in advance!
Thanks in advance!
#57
Originally Posted by sypher373
Hey all,
#58
Dude Thanks for the help. From the top of the engine? Or from down under, A picture would be great.
#59
Hi all,
Thought I'd ask about a strange problem I've been having for over a year with my Max... much like what Ham1987 described a few posts ago, in fact. Long after the engine has warmed up, I'll be stopped at a light and my idle will stay up around 1500, as if the automatic choke was engaged. Goosing the throttle will drop the idle back to normal, so it's more of an annoyance than a major driveability issue, and CEL hasn't come on. Friends have suggested maybe it's the throttle position sensor, maybe it's the EGR valve (I did test rather high on NOx at my last smog check)... Any input would be much appreciated. It's a 1995 Maxima SE 5spd, 99K, for those interested.
Thanks!
Thanks!
#60
hey i just have a real quick question there isnt really any place for me to ask this but this thread so here i go. i was wondering if anyone one know of a website that gives away free after market stickers or something like that
anyways thanks
anyways thanks
#61
anyways thanks
anyways thanks
#62
Nissan parts
kind of random but I do have enought posts to start my own thread. Anyways I just got a job as a porter at Bill Kay Nissan in Downers Grove, Illinois and can get nissan parts for a discount. I dont get it for cost but its a pretty good discount. Let me know if anyone is interested in anything. Im not asking for anything extra than what it would cost so its all good.
#63
#64
Is Monroe struts good enough?
Hi All,
My struts are getting bad and I have a good deals on "Monroe MacPherson Strut: Sensa-Trac". Is these struts good enough for my 96 MAXIMA? If yes, what additional parts should I buy along with these to change the struts?
#65
This is great phen, I have a 99 maxima GLE with a bose sound system & I am trying to get my ipod to play. Does anyone know which plug/adapter I need to place into the cd changer plug area? I dont want to spend $300 on a aux input adapter. (The plug that I'm looking for goes into the bose stereo and the RCA females jacks should be coming out). Or if you have a better suggestion. ALso, wanted to put on some 2003 350Z enthu stock wheels on my 99 max, but the 350Z wheels are staggered. Are they compatible?
#66
#67
In the how-to's is the thread for wiring in an aux for our Ipod on the stock hu. 350z rims should fit. Offset is important, not that the are staggered.
#68
Dont know the offset, but the fronts stick out approx 3-5mm, but the rear is perfectly flush. What to do?
#70
just got a hole in a section of my exhaust and now im trying to decide on whether too just get it repaired or go with a cat back system.Wondering what systems yuou would recomend in the lower price ranges seeing as i am far from loaded with cash.Also i am considering doing the install myself seeing as i am trying to do more of the work on my car myself but have never done exhaust work before.Just wonmdering how involved the install is , thanks
#71
all depends on what part of the section has the hole and how much you have to spend. install is easy if you have a torch. pain in the **** if you dont have one but have rusted bolts (as I am sure you do).
#72
#73
autotranny problem
97 Maxima. Recently my transmission coolant hose slipped off the nipple(clamp came loose) and I lost my fluid. When this happened I noticed rights away and pulled over, fixed the hose filled it with tranny fluid. It was fine for a couple days till it really started losing power and actually wouldnt move. My dads friend put more coolant in it and was revving it and shifting, it made a loud noise which he said was trapped air coming out of the tranny. It is now driving but seems like something is slowing it down faster when coastin and doesnt have as much power, I have a cat-back exhaust which used to sound nice and even the backpressure in that seems to have gone a little with the power. It feels as if there is something restricting it. ANYONE HELP?
#74
#75
one out of 4 windows not working
i have a 1995 GLE max which i bought used pretty recently, since i bought it my front passenger side window has stopped working. when i press the switch to roll it down from the main drivers panel or the single button on the passenger side door i hear a click as i press it and then no sound and no movement. all the other windows still work fine.
#76
#78
my car has been idoling around 1300 rpm's but sometimes its lower around 900 ,its to the ppoint where i dont even have to give it much gas when letting off the clutch in first gear, any ideas????
#79
look for new motor
#80
thats what i figured i would have to do. are there any ways of testing my old motor. and any instructions of how to install a new one on the forum? i figure it should be pretty straight forward but not positive.
