Whose got the highest mileage?? Any issues?
Old 07-04-2014, 05:21 PM
  #561
f2fitty's Avatar
98 gle 300k
f2fitty is offline
Old 07-04-2014, 06:08 PM
  #562
Bobo's Avatar
95SE, 5-speed
Just hit 159,000 kilometres today (100,964 miles).
Bobo is offline
Old 07-04-2014, 06:17 PM
  #563
Fakie J Farkerton's Avatar
IBTL
97 SE with 217,000 miles
97 GLE with 188,000 miles
Minimal work done to the SE. Radiator, plugs, rear calipers, both valve covers, FPR and fuel filter.
WAY too many mods and fixes on the GLE than I care to mention.
Fakie J Farkerton is offline
Old 07-04-2014, 06:22 PM
  #564
BlackAckMax's Avatar
'99 SE
285,000 kms
BlackAckMax is offline
Old 07-05-2014, 01:54 PM
  #565
Michael Feather's Avatar
98 se 430,000
Michael Feather is offline
Old 07-05-2014, 02:17 PM
  #566
Originally Posted by Michael Feather
98 se 430,000
Miles or kilometers?
Old 07-06-2014, 06:27 PM
  #567
98maxaholic's Avatar
Originally Posted by Bobo
95SE, 5-speed
Man, can there be very many 4th gens left on the road with less than 100k nowadays!
98maxaholic is offline
Old 04-05-2015, 09:14 AM
  #568
tnj9's Avatar
2003 GLE 164563 miles
Replaced:
Radiator
Control Arms
Exhaust (with catback system)
A/C Compressor
1 Wheel
1 Wheel knuckle
Rack and Pinion
Various Suspension Parts
Needs:
Power steering pump, just found it leaking majorly yesterday, ugh
tnj9 is offline
Old 04-05-2015, 10:16 AM
  #569
JoshG's Avatar
96 GLE 135k
JoshG is offline
Old 04-05-2015, 04:28 PM
  #570
martyl45's Avatar
95 gle 58k
Tps probably from time
martyl45 is offline
Old 04-05-2015, 08:36 PM
  #571
max ride 41's Avatar
95 with almost 270,000, any issues he says.....
max ride 41 is offline
Old 04-06-2015, 09:52 AM
  #572
Frank Fontaine's Avatar
I have 234,000k original miles on my 98 5 spd. I dunno if I can make 300k or not. Still original water pump and clutch, and I don't consider water pump DIY and not sure I'd want to pay to have it done.
I just did my radiator on Sat., as it started leaking in Feb. Was messier than I wanted it to be, couldn't get the drain undone, so I lifted it out with coolant and the fans attached
Do you guys think cars are made like this anymore?
I would like to buy another 15+ yr. car. We already have a BMW and a GM, and I've decided against a GTI. What I was thinking of was a WRX Limited. They are not great looking, but still made in Japan. Nice torque.....
Frank Fontaine is offline
Old 04-17-2015, 09:21 PM
  #573
watkins-mechanic's Avatar
199,000 miles on my 98 infiniti i30
Rust is my problem #1
Damn car cancer
watkins-mechanic is offline
Old 04-18-2015, 05:54 PM
  #574
asand1's Avatar
Runs great still, 96 5MT
asand1 is offline
Old 04-18-2015, 07:51 PM
  #575
careysward@gmail.com's Avatar
Mileage
95 GLE 169 k miles. Man what haven't I replaced... Most recently... Knock sensor, fuel injector, IAC, lower control arm bushings, left rear brake caliper, radiator, valve cover gaskets, both axles, fighting rust..I am addicted to this car.
careysward@gmail.com is offline
Old 04-18-2015, 08:51 PM
  #576
uttadms31's Avatar
236k miles, 1998 Infiniti I30, most of life in Northeast States
Still on original: Tranny, motor mounts, entire power steering system including tie rods, entire cooling system aside from new coolant, entire exhaust system aside from mufflers, fuel pump, coils, calipers, wheels, all engine seals/gaskets except valve covers
Main issue now is rust. I've had to start parking my car in the street overnight because after a rainfall I was getting rust spots along both sides of my car (near the edges of the car under the doors), even though only visible rust from the exterior is along the rear wheel wells.
uttadms31 is offline
Old 04-19-2015, 09:47 PM
  #577
Licensed to Spell
ptatohed's Avatar
Nice!
ptatohed is offline
Old 04-30-2015, 06:33 PM
  #578
Wolcottmax1's Avatar
236,000 miles and still going strong
Replaced various coils, brakes, tires, had 5 speed rebuilt, water pump, radiator, thermostat
Wolcottmax1 is offline
Old 05-04-2015, 09:43 PM
  #579
Licensed to Spell
ptatohed's Avatar
So, what's the answer? Who on the org has the highest mileage? Anyone hit 400k?
ptatohed is offline
Old 05-05-2015, 05:30 AM
  #580
asand1's Avatar
Lost my carpooling buddy, so I'll be driving 12,000 miles a year again, just for work. Hope to get a couple of road trips in too.
asand1 is offline
Old 05-05-2015, 09:15 AM
  #581
Daniel VQ30life's Avatar
97 SE 227180 right now, i know I'm not the highest but other than a coil pack here and there is mostly been the suspension worn out, had to change the clutch at 180 right after i bought it, dunno if it was the factory installed clutch or not
Daniel VQ30life is offline
Old 07-30-2015, 02:30 PM
  #582
Shock_and_Awe's Avatar
302,000 miles. Front axles need to be replaced. Very light seeping gaskets. Other than that, no major issues. Clutch may be going. Seem to slip the other day during acceleration. Like it was giving out. Probably time for a front end overhaul, new control arms, new struts, mounts etc etc. I put KYB Struts in there almost 3 years ago. I had Monroe in there before that. I know this may be sacrilegious to some, but, I think the Monroe's were a better ride. I also find that I get better acceleration when I use Mobil 1 Full Synthetic High Mileage vs Valvoline High Mileage Full Synthetic.
Anyone have a preference for Control Arms? Moog? A1 Cardone?
Cheers
Shock_and_Awe is offline
Old 07-30-2015, 06:08 PM
  #583
CS_AR's Avatar
Originally Posted by Shock_and_Awe
Anyone have a preference for Moog?
Yes. The problem solver line gets good reports.
CS_AR is offline
Old 07-31-2015, 12:00 PM
  #584
I prefer moog.I'm a mechanic and have done a lot of research on this stuff. 1.lifetime warranty.2.grease nipple on ball joint. 3. Moog claims that their bushings are not affected by grease and oil. Who's Max doesn't leak something.BTW Rock Auto parts pretty reasonable
Old 08-01-2015, 12:29 AM
  #585
ef9
ef9's Avatar
173,000 miles on my 1996 I30T
Parts that NEEDED replacement:
steering rack, tie rod ends, lower balljoints
radiator
evaporator, condenser, AC compressor, thermal expansion valve
all 3 O2 sensors
rear timing cover o-rings
struts
front wheel bearings
both CV half shafts
alternator
ef9 is offline
Old 08-01-2015, 05:34 AM
  #586
jerrod99_se-l's Avatar
99 se-l 435,000 miles....control arms...rebuilt tranny...axles....new bushings....headlight housing(turned yellow)...other things I'm sure I'm forgetting
jerrod99_se-l is offline
Old 08-04-2015, 02:58 AM
  #587
Trini Boom's Avatar
Can't remember when I last posted but have 365,000 and had to replace Rack and Pinion with low mileage OEM one and had dealer install it. Next is the sweating tranny cooler lines which I probably need to replace copper washers.
Trini Boom is offline
Old 08-04-2015, 05:10 AM
  #588
dwapenyi's Avatar
365K miles on NYC roads? What kind of suspension? OEM?
dwapenyi is offline
Old 09-21-2015, 09:25 AM
  #589
HiMi5SPD's Avatar
394,XXX Miles
96 5 Spd, original motor and tranny.
Inner and outer tie rod ends
4 motor/tranny mounts
3rd clutch
water pump
evap canister
D2 coilovers (to replace worn out struts)
Axle seals
RH and LH cv axles
HiMi5SPD is offline
Old 09-21-2015, 12:52 PM
  #590
JvG
JvG's Avatar
204,000 miles
purchased early 2006 with 101,000
two starters, radiator, recent water pump. brakes, windshield, battery,
egr blockage.
Not bad for 100,000 miles of driving. This car might last ten more years.
JvG is offline
Old 09-22-2015, 05:58 PM
  #591
bbsitum's Avatar
Both car at auction for 500$ and 140 000 miles. Today 218 000 miles. Replaced so far brake pads front and back a few times. Front left brake caliper 2 times and rear left once. Both drive shaft and front left bearing. Alternator too. Everything else work in car perfect or near perfection. It is Infiniti i30 97. and it is best car I ever had regard amount of fixing needed.
Edit. Of course lower radiator support is rotten. It was rusted through, engine hanging in air when I both it at auction. Was looking for other car part at Upull and find at another Nissan maxima thick metal L profile that hang at lower radiator support. Toke it off and pay for it 60c. Screwed L support to not rusted part of lower radiator support with sheet metal screws. Hold still always.
bbsitum is offline
Old 09-23-2015, 10:30 AM
  #592
rayz336's Avatar
I have 263,000 miles on my 1998 SE and no real problems
rayz336 is offline
Old 09-29-2015, 04:58 PM
  #593
239,000 miles on my 98 SE. Just did the starter. Previously;
clutch 195,000
valve cover gaskets
lower ball joints
struts x2
drive shaft seals
Old 09-29-2015, 08:47 PM
  #594
My Coffee's Avatar
Does TMU count? Lol. My best guess with carfax is 350k + ... but I guess I will never know.
My Coffee is offline
Old 09-30-2015, 08:19 PM
  #595
Lizziebeth13's Avatar
313,xxx on my '95 GLE. Couple of water pumps, ignition coil, radiator last year. Drove it 5 hours to the beach and back home this past summer.
Was running great until last Friday night when the battery and brake lights came on. I pulled over, popped the hood and the damn thing caught fire. Still waiting to hear back from my mechanic if it's worth trying to fix. God I hate car shopping.
Lizziebeth13 is offline
Old 10-01-2015, 12:51 AM
  #596
438,000 ignition coils and radiator fan motor
Old 10-01-2015, 12:59 AM
  #597
ef9
ef9's Avatar
Miles or km?
ef9 is offline
Old 10-01-2015, 02:12 AM
  #598
Originally Posted by ef9
Miles or km?
Miles!
Old 10-01-2015, 09:54 AM
  #599
ef9
ef9's Avatar
Miles!
Oh my goodness! That's crazy.
I would think the engine would need a rebuild at that many miles.
I only have 175,258 miles on a 1996.
ef9 is offline
Old 10-01-2015, 11:54 AM
  #600
I bought her from the orig. Owner who worked at a Nissan dealership and a certified Nissan mechanic...trans rebuilt right before I bought it...
Quick Reply: Whose got the highest mileage?? Any issues?
