ODBII reader says catalyst not ready - Maxima Forums
Thread Tools Search this Thread
Old 02-27-2008, 07:33 PM   #1
I have 95, maxi gle, its due smog check.
Just for the experiment I hooked up an obdII sensor to car and run some I/M tests. Everything comes good except one catalyst option. OBD reader indicate that catalyst not ready.
There is no MIL light, I had removed battery a while back and driven about 50 miles since putting battery back.
I know for 96+ maxima's there is a TSB which talks about smog inspection, I am wondering if a something similar exists for 95 california spec maxima.
Otherwise what can I do for "catalyst not ready"
nitink is offline   Reply With Quote
Old 02-27-2008, 07:52 PM   #2
get it ready....i guess.
Snypa is offline   Reply With Quote
Old 02-27-2008, 07:55 PM   #3
member
take it out on the highway and give it a good run for a while then try it again
slow97maxima is offline   Reply With Quote
Old 02-28-2008, 05:00 AM   #4
yeah just drive it for a while and that should take care of it.
fat_kid is offline   Reply With Quote
Old 02-29-2008, 07:32 AM   #5
To complete the drive cycles in order for the system to be ready, usually you need to have a couple cold starts (air temp and coolent temp within a few degrees) and have it warm fully up, spend a few minutes above 50mph, different stuff like that. Just take it back in a week and you should be fine. Good luck!
Chief Brody is offline   Reply With Quote
Old 03-02-2008, 02:42 PM   #6
got p0136 code
Thanks for the reply guys.
I have driven this car about 100miles this week, cold starts everyday than on freeway. OBD still says catalytic converter not ready but now I got code p0136, rear O2 sensor.
Is it sensor or it is catalytic convert?
Old 03-02-2008, 02:44 PM   #7
i had this same problem, i logged over 500 miles before it went away. do a lot of stop and starts, mixed driving(highway and city) and just keep doing it
Old 03-02-2008, 11:48 PM   #8
KRRZ350's Avatar
Are you sure it is a cali spec/ Because I know that the catalytic converter readiness check WILL NOT GO READY ON A '95 FED SPEC (OR '96 FED SPEC I30) It will ALWAYS read incomplete.
Ask me how I know this..........................
Just take it for the test, it will more than likely pass, if the tester tries to tell you it won't tell him to run it and to try anyways. This is what ended up happening on a '96 fed-I30 (Which FYI is different from a '96 maxima, ist is similiar to '95 fed-spec maxima in several emmisions regards ie: no evap purge control volume valve) I pulled my hair out for almst 2 months trying to get it to go ready, new o2's, different cat, IAT sensor (Which is only used by ecu for catalst srt), than one day a test guy said "Hey, even some '96's won't always go ready but they pass anyways because the state computer knows it's one of those cars" sure enough............
KRRZ350 is offline   Reply With Quote
Old 03-02-2008, 11:56 PM   #9
KRRZ350's Avatar
Missed this post, It is rear o2 sensor for sure (well, or wiring, lol), replace it, wait for the o2 and evaps to go ready (they are always last, more criteria), and if catalyst SRT still isn't ready take my above advice afterwards.
Old 04-22-2008, 01:06 AM   #10
how can i determine which sensor is not ready? I've gone trhough emissions 5 times now with a 96 Maxima, and all have come back rejected. Tookit to the dealership, and they said the knock sensor was bad causing it to not be ready. I replaced the ks, but got rejected again. It's getting a little annoying now.
thanks guys
orange57 is offline   Reply With Quote
Old 04-22-2008, 11:38 AM   #11
No more Maximas...
pmohr's Avatar
Quote:
thanks guys
CEL? Are they specifying what system monitor is showing not ready?
pmohr is offline   Reply With Quote
Old 07-24-2008, 10:05 PM   #12
BEst thing is get the OBD2 reader. If you are really getting the knock code PO325 then do the bypass just for the smog test. It worked for me, i wouldn't recommend keeping it that way though. Just my $0.02
eazymax is offline   Reply With Quote
Old 07-25-2008, 02:40 PM   #13
I agree with the above. You should just get an OBD-II reader. I had 4 codes when I took it to Autozone, and was going to try and fix all of the issues, but then a couple of weeks later I bought a reader, and it said I only had 2 codes. Have reset it for now and am waiting to see what shows back up.
exchange240sx is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Bringing my 1996 Maxima back to the road after 8 years. My Coffee New Member Introductions 14 12-17-2016 01:40 PM
Amp Mounting Location sliptap 7th Generation Maxima (2009-2015) 2 09-30-2015 06:57 AM
Another one bites the dust Marc2theMax 5th Generation Maxima (2000-2003) 4 09-28-2015 09:13 AM
Not a Maxima...but NissanNismoZ 6th Generation Maxima (2004-2008) 4 09-12-2015 08:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
