Power Steering Hose leak
Old 10-16-2011, 10:41 AM
  #41
plugeye's Avatar
bump. any news/ changes?
plugeye is offline
Old 10-17-2011, 12:41 AM
  #42
Snypa's Avatar
culprit = valve cover
Snypa is offline
Old 10-20-2011, 04:01 PM
  #43
Semperfi2t2's Avatar
hey guys. can you help me out in identifying whether this hose is a high or low pressure hose. and where i can get one for cheap?
Semperfi2t2 is offline
Old 10-20-2011, 04:16 PM
  #44
Snypa's Avatar
rear main seal OR upper oil pan seals.
Snypa is offline
Old 03-30-2012, 01:31 PM
  #45
bchristianmdd's Avatar
I replaced my power steering pump per my suspicions and the Dodge Dealer's confirmation. I now noticed after tightening the bolts, and including all gaskets (1 rubber for the return and 2 copper for the high pressure) that I exposed a leak from flexing the hose. I believe it is coming from the return line. That spicket that has the two bolts that go into the power steering pump, is that removable and I just buy a measured piece of hose? Or do I need an OEM hose with that attachment already on it? Can someone please provide some feedback?
bchristianmdd is offline
Old 03-30-2012, 07:56 PM
  #46
ATTappman's Avatar
The suction hose and the inlet connector (what you called the "spicket" meaning spigot, I guess) are two separate parts. Loosen the hose clamp and slide the hose off the connector, which remains bolted to the pump.
ATTappman is offline
Old 03-30-2012, 10:00 PM
  #47
organ donor's Avatar
what kind of hose?
You can get the P/s return house from Napa or any parts house... 5/8" make sure you put that heat shield back on or something equivalent to it do to high heat and possible rubbing. no need to buy special preformed from Nissan. Make sure to tighten those hose clamps and clean fluid off the fittings where the hose goes on before placing hose on them. good luck
organ donor is offline
Old 06-06-2012, 08:56 PM
  #48
Snypa's Avatar
Just getting around to this. Myself and a friend of mine seem to have similar problem. Got a hose that's in great condition and some different looking (hopefully better too) clamps (clamps on 99 look different that earlier models).
Snypa is offline
Old 06-07-2012, 03:45 PM
  #49
Trini Boom's Avatar
So the 99 is leaking as well? If so, the return hose is splitting at the pump or the clamp is not tight enough, If it is splitting, I would just replace the hose.
Trini Boom is offline
Old 06-07-2012, 08:25 PM
  #50
Snypa's Avatar
Issue was always on the 99 maxima. Yeah, i have the screw clamps that was used on earlier generation, got my good condition hose...just need a good day to get this done. In the meantime, im taking out old fluid and replacing with new until the fluid is pure red.
Snypa is offline
Old 12-23-2012, 06:32 AM
  #51
Hein's Avatar
I think I'm on the same boat as you guys.. just got this 99 Max and the p/s fluid is all over the return hose and it's also leaking at the other end as well, closer to the radiator and as a matter of fact, the bottom of my radiator is covered in the fluid too.
I will probably replace the return hose and readjust all the clamps or get new bolt clamps.. my question is, is this a reason to get a new P/S pump??
Hein is offline
Old 12-23-2012, 05:11 PM
  #52
Snypa's Avatar
Not a reason for a new pump unless the pump is giving some sort of issues. Return hose was my culprit and the two small lines coming from the reservoir.
Snypa is offline
Old 03-16-2013, 09:41 AM
  #53
plugeye's Avatar
leak on my 99 SE got a little worse, worked on it today & the return hose at the pump is seeping. replaced the clamp with worm-gear clamp & no difference. so i'll get some ps return hose, 5/8" someone mentioned earlier.
2 feet should do it
plugeye is offline
Old 03-24-2013, 12:10 PM
  #54
Snypa's Avatar
2 feet should do it
def new hose and new clamps too. I find that the 99 clamps eat the fck outta the hoses. Goodluck.
Snypa is offline
MR2 T'd
07-09-2021 05:06 AM
lowpost99
05-16-2021 11:18 AM
captchaos
03-15-2016 12:18 PM
aminus21
09-12-2015 04:53 PM
dcam0326
09-07-2015 07:26 AM
Quick Reply: Power Steering Hose leak
