95 Maxima rear speaker wire polarity
Take a battery and some scrap wire, run the positive end of the battery to one terminal and the negative to another. If the cone moves out, its wired correctly and if it moves in its wired incorrectly, so then by process of elimination figure out which is positive and which is negative.
If you are looking at the wire not the speaker, usually the negative wire in a automotive audio wiring harness has a black stripe.
This is ONLY correct in AFTERMARKET wiring, not in factory wiring. NEVER assume a original wire is negative because it has a black stripe.
jskirwin
06-08-2016 08:49 AM
Huttig2009
09-25-2015 03:31 PM
Maxilano
08-31-2015 07:33 PM
