my car is jumping at stops - Maxima Forums
Thread Tools Search this Thread
Old 08-30-2011, 04:52 PM   #1
i got a 96 auto and when i stop at a light it feels like my motor is jumping.at first it was only at lights and now it does it while i am driving some times.some times it feels like it is gonna stall on me. there are no cel codes either. i was told it was my torque converter and then i was told it could be bad fuel injectors also. i am stumped any input will help, and when i first get in to go anywhere it takes a minute to star the car i have to keep turning the key then letting off then turning it over again i have to do that 2 or 3 times before it will start
joseph.mcgowen is offline   Reply With Quote
Old 08-30-2011, 05:02 PM   #2
CEL on?
ChrisMan287 is offline   Reply With Quote
Old 08-30-2011, 05:28 PM   #3
Quote:
Question: Say you have a hard time starting, and get it started, cut the car off, will come right on? or do you have to try cranking it multiple times?
tigersharkdude is offline   Reply With Quote
Old 08-30-2011, 10:57 PM   #4
sounds like a misfire...coils\plugs been changed ever?
BronxSleeperMax187 is offline   Reply With Quote
Old 08-31-2011, 07:19 AM   #5
sounds like one of the crank sensors. Prolly rear crank sensor. Test both and CPS.
Remember a resistance test with the crank sensor tells u nothing. The test for the CKPS is a voltage test.
cashoit is offline   Reply With Quote
Old 08-31-2011, 07:50 AM   #6
Definitely a misfire.
Causes:
1) Fuel injector
2) Spark Plug
3) Coil Pack
I'm willing to guess it's ignition related **cough*** coil pack...
njmaxseltd is offline   Reply With Quote
Old 08-31-2011, 08:06 PM   #7
@ nj max its not a misfire but it does almost feel like one and i have done all my coil packs and plugs but not injectors yet and no cel
@ cashoit where are the crank sensors and if you have what the resistance should be that would help
@ tigersharkdude just have to keep cranking but this morning before i went to work it shut off when i put it in reverse and pressed the gas but that is the first time it has done that
Old 09-01-2011, 01:35 PM   #8
i assume you have already cleaned TB and MAF, replaced PCV and ECTS.
Read my earlier post. A resistacnce test tells u nothing about the crank sensors. Test for the cranks is a voltage test.
The test for the Camshaft postiion sensor is a resistance test
Old 09-01-2011, 09:10 PM   #9
@ CASHOIT my bad i wasnt thinkin when i replied and it is probably my camshaft position sensor because oil is leaking from around it i didnt realize that until today when i went to look
Old 09-01-2011, 09:43 PM   #10
oil leak there is common, just change the O-ring
Old 09-02-2011, 03:45 AM   #11
i have this problem too, i have a cyl 1 misfire...and a solenoid A trans code, either way... i replaced the coil and the plug, next step is the injector...not lookin forward to doin it, DO'H
MaxJammin is offline   Reply With Quote
Old 09-02-2011, 06:00 PM   #12
so the oil dont mean my camshaft position sensor is bad?and i tried to get the o-ring today but they dont carry it at autozone anyone know where to get it
and @ maxjamin i am throwing no codes it has been scanned multiple times when i first the bought the car i threw a p0731 (1st gear malfunction) but that just went away other than that any codes that have been thrown were fixed so i dont think it is a miss but i might as well try an injector to
Old 09-04-2011, 03:05 AM   #13
well, i would say compression test it, and change the plugs/coils and then maybe the injector, im just gunna live with it untill next year (cars goin under the knife BIG TIME
Old 09-06-2011, 01:20 PM   #14
so the oil dont mean my camshaft position sensor is bad?and i tried to get the o-ring today but they dont carry it at autozone anyone know where to get it?
Got it at the dealer - cost $4.
bobflood is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
2006 Nissan Maxima Tranny problems? Lakersallday24 6th Generation Maxima (2004-2008) 4 06-23-2016 10:12 PM
Stutters,bucks,jumps at 2000-3000rpm kjlouis 4th Generation Maxima (1995-1999) 9 08-17-2015 08:36 PM
Braking system.. Costa068 6th Generation Maxima (2004-2008) 1 08-17-2015 03:13 PM
Bad Alternator? EVAP & EGRC Codes? doobadoo 4th Generation Maxima (1995-1999) 2 08-15-2015 07:43 PM
No Air - My Experience with Repair kirkhilles 5th Generation Maxima (2000-2003) 2 08-08-2015 11:53 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
