How To: 4th Gen Plug and Play Interior LED Thread
#41
#44
its kinda ghetto but i was able to do it w.o soldering so it works fine for me.
i bought http://www.superbrightleds.com/cgi-b...nstrument.html , the T1.5 series LED Twist Lock Lamp(at the bottom of the page) in blue, pulled them out of thier base, (they are made to work w 12 volt) and wrapped each connecter from the LED around the corresponding "prong" on the hazard or defroster switch. these led's have resisters and what not already hooked up to them...and viola they worked, its not that hard. didn't reuse the rubber connecter of course cause these bulbs are bugger than the stock.
its not exactly plug and play like the dash bulbs or climate control bulbs were but i assure u i soldered nothing
im not here on the org to bull**** everyone, just my way of doing it....well my way
#46
#49
#52
so for your 5 cluster bulbs which size did you use? the 3,4, or 5mm ones? I like the cool blue dash gauges and odometer backlight.
edit -- I noticed where you said the 5mm ones. reading is good.
#54
(superbrightLEDs.com)
NEOx-xHP: NEOx High Power LED Instrument bulb
NEO5-WHP: 5mm NEO5-xHP Cool White
Qty: 5, these are the instrument panel bulbs
(ebay)
http://www.ebay.com/itm/180761966937...witem=&vxp=mtr
Qty: 2 (these are in a pack of 2, so I got a total of 4 LED sets) These will be for the map and door courtesy lights.
http://cgi.ebay.com/ebaymotors/ws/eB...m=290598043276
Qty: 1, this is for the main dome light
I didn't get licence plate lights yet since I don't want the cops making it easier to see me :-) ...or maybe it was because I ordered these at 1am and was fading fast...
#55
I got the following bulbs:
(ebay)
(ebay)
http://www.ebay.com/itm/1-x-White-LE...ht_5361wt_1396
#57
Can anyone link me a cheap rear license plate bracket for the bulbs? I know I fab one up with wood, but I want to see if there are any PnP I can buy. I tried local parts store, seems I Can't even buy the actual bulb covers from there...let alone the long plastic trim to hold them.
#58
Can anyone link me a cheap rear license plate bracket for the bulbs? I know I fab one up with wotod, but I want to see if there are any PnP I can buy. I tried local parts store, seems I Can't even buy the actual bulb covers from there...let alone the long plastic trim to hold them.
#60
message him about buying a bracket...........or make your own
http://forums.maxima.org/4th-generat...t-bracket.html
#65
to properly fit in on the .org I have decided to order some LED's for my 4th gen. Ordered fogs from SuperBright to start off in the amber color. Dont know how amber they will be though as its a hard color to match...
#66
vanity mirror bulbs (seller on ebay...personal website)
http://www.wardenjp.com/stores/festoon.html
#67
beside making the housings yellow (IMHO it looks great on white cars)
you get a little bit of damage protection (Rvinyl film is pretty thick)
and it puts out some YELLOW light
on that note, im not sure how bright the led bubls for fog bulbs will be
#68
This Just In
Neo-4 bulbs fit in the 99 ACC w/ AMB button
(NOTE: the hot spots arent that bad, I had to use a somewhat high ISO to take the pic without a tripod)
#70
#74
depends. the ones that have the base, just rotate THE WHOLE THING 180 and reinstall. The ones that are just the bulb, pull out from the base, rotate bulb 180 and reinstall
#75
or like he said BUT even on the ones that look like a normal bulb and have a base, you remove and rotate THE WHOLE THING 180* and reinstall
#79
just did my Gauge Cluster lights...INCREDIBLE difference from the stock and Cool White LEDs....WOW.
Before, with stock bulbs:
After, with Cool White LEDs:
The stock cluster lights look a bit yellow in person even though it looks white in the pic. The new white LEDs aren't as blue in real life as they appear in the pic. Also, the hotspotting in the pic of the LEDs is not nearly as noticeable to the naked eye...I can barely see any difference, but I know where it "should be"...
