How do I identify and LSD transmission
Also IIRC.
If your maxima is from the U.S. you do NOT have a VLSD.
Only Canadian maximas had VLSD.
As for I30s.... Different story...
So here's the rest of the story. I thought I bought an lsd transmission from a junkyard on Tuesday(30 day warranty). VIN on the tranny is JN1CA21D6WT529728. I ordered an axle from Rock Auto. EMPI part number 804598. If you go to nissanpartsasap.com and enter in the VIN above, you get that it's a 98 Maxima manual. Last night I get the axle and I go just to make sure the axle fits and it won't go in all the way.
I think there might be a pin the middle where the axles meet so I'm guessing it's not lsd. I can't remember and waiting for someone to send me a picture to verify. So now I have to go get my money back and look for another tranny.
i checked into that a while ago and i thought i found that theres a tag on it somewhere that identifies it. the vlsd had an extra letter at the end or something but dont quote me, it was a manufacturer sticker next to the metal id tag. of coarse yours may be gone as mine was in terrible shape. hope this helps
It will say "LOCKER" on the side j/k
if you have another transmission to compare it to, the driver side axle hole is a lot bigger than the non locking diff. and the other easy way to tell that has already been stated is looking though one axle hole and being able to see out the other side. The vlsd driver side axles are harder to put in than a non vlsd axle, so I would not base everything off of the axle not going in right away. Check the other two obvious things first before you give up on it.
A small metal plate on the tranny identifies it, I may be able to grab a pic when I get home.
The best way to tell is on the driver side on a VLSD there are 2 sets of splines you have 1 set than a different set for the actual locking of the differential further inside the diff.
True, but at this point in time most VLSD's have failed, and you can have a former locking VLSD transmission but it no longer does it's deed any more.
Also IIRC.
Also IIRC.
Part of wat u wrote is wrong, the correct info is SOME u.s.a maximas had vlsd not all but some
Infinite i30
If I don't have limited slip on my 1999 infinite does that mean I don't have a locking diff? Wold that make it an A or B transmission.
If you don't have limited slip, you don't have locking diff.
Check the tag under the hood, at the passenger's side, there's a plate there, at the firewall, ot has the VIN number,
Look where it says transmission. If it ends in an A, it's LSD. If it ends in V, it's not.
Example:
Locking diff = LSD
Here
Pied
09-26-2015 03:29 PM
