a/c compressor not turning on.
You can jumper it at the pressure switch. It is located between the battery and headlight area next to the radiator and condenser. Unplug the switch that is in the dryer (aluminum cylinder with 2 tubes) and use a piece of wire in the connector.
Do I take one piece of wire and put in the connector and then to the battery?
Jump directly to the positive terminal of the battery. The compressor will turn if its clutch is good. If so, chances are that you are low on r-134. Get a fill kit at the parts store. If you only need to fill it once a year or so, call it good. Cheaper to add more gas than to fix the problem. It might make sense to find the leak if you need to fill up once a month or more
If you pull the connector off of the pressure switch by the battery, jumper Pin 1 to pin 4 in the wire harness connector - pin 1 = green with black stripe, pin 4 = light green with red stripe.
What I feel is easier to do is remove the air conditioner relay and put a jumper in the socket from pin 3 to 5. Look on the bottom of the relay for pin numbers. The power steering relay is by the power steering oil reservoir.
Does the power steering relay tie into the compressor wires?
Finding the Freon leak.
You have options.
1. Add r-134 until the pressure meter indicates it is charged. If the A/C works now, you win. If it keeps its charge, you win. If you need to add a can of refrigerant once a summer, feed its habit.
2. If the R-134 leaks out too fast, you will need to actually fix the leak that causes the problem.
3. Open the windows and drive the car. That is what we did before A/C became common.
You say that you do not have much money. Options 1 or 3 apply in your case.
Have you connected your compressor lead to the positive terminal of the battery while the car is running yet? This is the easiest way to see if the problem is just that you are low on 134.
You are over thinking this. Does it have enough 134 or not?
You have options.
I connected the wires and the compressor came on. It looks like I am low on freon. To add freon do I need to have the compressor running or can I just add the freon without having it on?
1. you need to buy a kit that has the r-134. it will have a can of r-134,and a hose. Buy the kit that has a meter. It will help you put in the right amount of gas. not too much, not too little. Re-attach the wire you dis-conmnected. Now turn the engine on. Look for the light green cap right next to the p/s fluid container. Remove cap, attachj hose to the kit. It is a good idea to have a dishpan full of hot water to put the can into. It will help it fill the car quicker. Follow the instructions on the kit. Quit adding when the guaage reads Normal. Usually one can is enough, but you might need two. It really is that easy.
Does you kit provide instructions for charging and what to do if your high side is too low and the low side is too low?
First get the engine running. Then turn the a/c switch on the dashboard to ON. Now do the filling. Please do some research opn you own, like on youtube, the net, haynes anything. There is bound to be information on this forum, do a search. We are here to help you, not spoon-feed you. Read the instructions that come with the kit. It is not rocket science.
Did you re-connect the wire from the compressor? Is the A/C switch on the dashboad on? If the plug is connected and the a/c switch is on, the compressor should have kicked in once you got enough pressure in the system.
Time for a shop or roll down the windows I guess. I have told you how I did this on my Maxima, a 94 nissan pickup, an 84 nissan pickup and other cars. THis should have worked. Now check your fuses like the other members have mentioned . Iam out of suggestions. Good luck.
Check whether the voltage is too low ... or a capacitive load is too heavy or burned down ... I suggest to find a professional repair it.
THe first thing to do is to determine if the system is holding pressure or if there is a leak.
Use the pressure gauge on the can to determine how much freon is in the system.
If u added freon and the pressure does not go past zero, then the system is not holding pressure and u have a leak. Like others have suggested, get the freon with dye to locate the leak.
If u dont have a leak and the system is holding pressure, keep adding freon until the guage needle is in the green. The fans should kick on. If the fans do not kick on, then u have a more difficult problem and report back your findings
bryants95max
10-02-2015 12:52 PM
pears
09-18-2015 05:25 AM
