Q45/J30 front brakes on A32
Went to a San Antonio junk yard that really was nice how they had all the makes categorized.....Made a swap in the junkyard placing 93 J30 twin piston calipers, torque member and rotors on an A32 chassis! The only problem I see is the splash shield will need to be removed because it interferes with this thicker rotor... Other than that if 93/94 J30 pads are ordered they will fit without all that milling this and that! I figured I would investigate how they fit because I wanna do both my 3rd and 4th Gen with beefier brakes to ensure I have the power to stop if needed!
Q45
If you use 1998 Q45 rotors and calipers you will need to drill out mounting holes (on spindle) for front calipers. You will need to reuse Q45 mounting bolts. Also, the 98' Q45 rotor will need to be turned down a few mm to clearance caliper.
According to Autozones specs the rotors are basically the same diameter, but the J30 is 28mm thick vs A32 22mm. FWIW the A33a (00-01) is same diameter but 26mm and thats what I have. The J30 rotor is 53.7mm thick overall while the A32 is only 49.3mm. Not sure how thats going to work out good or bad. I know the A33 and A34 stuff swaps over with just enlarging the bolt holes on the knuckle.
If you want bigger brakes you can also look into 02-03 (16"+ wheel) or better yet 04-08 (17"+ wheel).
Just get 6th gen front brakes... I did that and I have over 100,000 miles on the rotors. No warping, where as I went through 3 sets of 5.5 gen rotors before hand in less than 60k miles.
1993 J30 brakes on an A32
03VQMAX
09-25-2015 04:19 PM
MAXSE5SPD
08-23-2015 12:06 PM
