Car stall out and idles rough
Before any of you flame, I did have the CEL for EGR being clogged. Sooo I removed the EGR and yes it was clogged so i cleaned it out thoroughly with carb cleaner, removed the IAC valve and cleand that as well. The CEL for the EGR (0400) is gone but the car still runs like crap/stalls out and boggs.. pleasee help me
With nissans I come across are bad maf. Try cleaning it with maf cleaner an let dry then install.
If it runs good for awhile then back again maf mite be bad.
If ur car bogs and dies when hot only it can be a bad coolant temp sensor.
Let me know
Let me know
I did clean the maf with the correct cleaner and still runs like ****.. where is the coolant temp sensor?
By silent codes do you mean codes that do not give you a check engine light?.. if so then the only one I have now is for the knock sensor.
Ok, I'd move on to looking for obvious vacuum leaks, then temporarily install a fuel pressure gauge and test the FPR and fuel pump.
One quick test is to pull the vacuum line off the FPR and see if any gas is present. If gas is present, the FPR is toast. Although not a dead giveaway that the FPR is bad (if no gas is present), it is one quick and easy test to perform.
I've personally seen a bad ECTS turn off a max while driving, but it didn't cause any rough idling, stumbling upon acceleration, or other side effects. So, I don't think this is the reason, but a quick check with your digital volt ohm meter can rule it out.
It could be the MAF.
Is the car driveable? Or are you saying it's un-driveable because these symptoms start as soon as you try to drive it?
It will run good for a while.. n then it would start hesitating/jerking and idling like ****.. n then it would run fine again and then bad again.. so I'm thinkin bad maf maybe?
I reused the original gaskets. I will check for vacuum leaks in the morning.. I do appreciate all the great feedback you guys are giving me
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
scarletsosa
08-17-2015 09:09 PM
Maxboy23
08-11-2015 11:59 AM
