Crooked steering wheel
So my issue is that even though I have the steering wheel in-line with the wheels to make the vehicle go straight, for some reason the steering wheel turns to the right (1-2PM position) by itself along with the wheels.
I thought two things. One being memory steer due to faulty components whatever they may be or perhaps the natural center for steering is off so I need to readjust the steering wheel and wheels to the natural center. Whether I start with the steering wheel or wheels something doesn't work. If I start with the steering wheel to make it straight (12PM) and then proceed to the wheels the previously stated scenario happens. If I start with the wheels and make them straight ignoring the steering wheel and turning them to the left via tie rod adjustment the vehicle still pulls right and even worse the steering wheel is further turned right to like 2:30PM position.
I'm starting to think there's some sort of suspension issue like ball joints, but those seem good. Perhaps the steering rack is worn?
No matter what I do the vehicle and steering wheel will want to go right unless I adjust toe to make the wheels completely left and in that case the steering wheel will be completely right.
Check for worn out suspension and steering components, bushings, ball joints, tie rod ends. If everything's tight, have the front end aligned, make sure camber and caster are in spec. If camber and or caster is off, you've most likely got something bent.
Ya, getting an alignment is my last resort...but it looks like that's where it's headed as everything looks good...wonder what I'll find..
I realized it's harder to turn left than right...and when it's on the lift the steering is equal left and right, so I now am aiming toward a rack sealing issue.
You need to set the steering wheel in the middle and adjust each wheel accordingly. If it still pulls, your camber or caster is farked.
Sounds like caster or camber on one side is out, unfortunately this is not adjustable, and could only result from an impact.
Not very likely. If the spool valve in the rack was farked it would pull, but also turn to full lock with zero input from you.
"This can be checked by raising the wheels with the engine running to see if the wheels turn to one side by themselves. No change would indicate another cause, but if the pull suddenly vanishes an imbalance in the power steering system is to blame. The control valve assembly or steering gear needs to be replaced."
I raised the vehicle and the pull disappeared like it said.
What you say makes sense, but is this diagnostic information backwards or something?
JoshG
51
09-21-2015 10:41 PM
