hello i got a problem with my gauges
Old 12-27-2014, 04:29 AM
eraygoza's Avatar
the instrument cluster in my 1997 maxima is completely off nothing works on it can it be a fuse???
eraygoza is offline
Old 12-27-2014, 05:43 PM
Yup, start checking. There are fuses inside the car and in the engine bay.
I'd start with the 10A Meter fuse. This fuse can be found behind a panel under the steering wheel and where your left knee would be if you were driving.
The Wizard is offline
Old 12-27-2014, 08:34 PM
No more Maximas...
pmohr's Avatar
Quick test, do your reverse lights work? If so, it's not a cluster fuse problem.
The only fuse that powers the cluster is that 10A meter fuse that The Wizard pointed out, but it also directly powers your reverse lights.
pmohr is offline
Old 01-01-2015, 04:03 PM
eraygoza's Avatar
thanks
Thank you guys you save me a buch of money
eraygoza is offline
Old 01-01-2015, 04:31 PM
Daniel VQ30life's Avatar
Use a continuity tester and check all of them at once, it's quick, easy, And may save you further headache if something else is out that you don't know of, like tail lights
Daniel VQ30life is offline
Old 01-01-2015, 04:33 PM
JoshG's Avatar
what was the problem? did u fix it?
JoshG is offline
Old 01-02-2015, 07:54 AM
KP11520's Avatar
If it's that same 10a fuse, your battery won't charge either and the car will die somewhere on the road. OUCH!
Been there... Done that!
KP11520 is offline
Old 01-10-2015, 09:37 PM
Bump, although I'm assuming it was just the meter fuse and that we won't be hearing anymore from this person
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
BrandonCause
09-14-2015 10:41 PM
kadespraggins
09-14-2015 12:04 AM
NissanNismoZ
09-12-2015 07:30 AM
Quick Reply: hello i got a problem with my gauges
