How Many Knock Sensors are in a 95 Nissan Maxima?
One knock sensor under the lower intake manifold. Is your car a California model?
Here's a video. I use a 1/4 in drive with a universal joint to remove the KS bolt.
Yes, only one knock sensor. The KS uses a piezoelectric crystal to sense when a knock occurs--this sends a voltage to the ECM to adjust the timing to prevent engine knock. The KS code shows up a lot when checking codes--some call it a ghost code, because when you fix the other problem, the KS code magically goes away. My 96 Quest was the same way, it would show a KS code if any other code showed up. I wish I had $5 for every unnecessary knock sensor replacement that was done on Nissans in this country.
kjlouis
11-24-2018 06:09 AM
xUNIxPanther
08-27-2015 10:09 PM
