Car wont start after intake manifold, rear valve cover job
Had a leak in a rear spark plug tube so like all good maxima owners I took on the challenge of doing the rear valve cover seal, spark plug tube seals and such.
Removing the intake manifold is a *****. Broke a valve cover bolt, sucks no biggy... New spark plugs installed while its easy and they are needed anyway NGK PFR5G-11 2647, new fuel lines installed around the fuel rails and the fuel pressure regulator, new pcv valve. Get everything put back together double triple check connectors, hoses, car turns over perfectly fine but will not fire. Tried cycling on the key without starting 5-6 times still the same, turns wont fire dosnt pop does nothing except turn. What do I check? I went back with a flashlight and looked at all electrical connectors, hoses, intake, cant find anything wrong. Neg battery terminal was disconnected while working on car btw.
Took the intake off and was looking things over, saw the hard line EGR tube gasket laying on the trans housing.. would this cause the car not to start? Before I tear the intake manifold off again to install this gasket.
Not sure if it is the cause but I'm positive it will screw up your idle so you'll need to add the gasket either way. This gasket was the most frustrating part of the process for me. I'd recommend light superglueing/RTV it beforehand and a bit of luck that it stays on. And next time before you tighten its two bolts and reattach everything, feel to make sure it's there so you don't have to do it all again, I'd check for codes if you have any to see what you're issue might be. I've never worked with fuel lines so not sure if it could be something with that
you should check to make sure all the coilpacks are plugged in, and secure, and that your fuel line as fuel going threw it, those are the only things needed to start the car, it turns over so the starter is working, it's either no spark, or no fuel...
Manifold removed EGR gasket installed. All connections were checked. Found a small vent hose on the intake right behind the right side of the throttle body that wasnt hooked back up but it should still start even with that. Hooked it up... FINALLY found a loose wire a the crank position sensor. FIXED! car starts and runs great.
MAXSE5SPD
08-23-2015 12:06 PM
Nintensity
08-13-2015 05:41 PM
Maxboy23
08-11-2015 11:59 AM
