help with lower control arm
Need some advice...wheels on ground...i can put my foot on the tire and push it towards the back of the car....when you look under the car and do it...you can see the control arm shifting toward the back of the car...im going to assume the arm is toast...im also going to assume under throttle the arm is shifting to the back causing my tire not to be centered and making it shake really bad...anybody had this problem in the past..ive done the 12 and 6 and 3 and 9 with wheel off the ground and there is no play at all...control arm bushings shot?...just replaced the tie rod ends last week...any comments are more than welcome
All I can say is the job isn't that bad... just did both LCA's on a 1996 (Moog's from RockAuto) and they fit perfectly & included all the bushings & ball joints pre-installed. You'll need a ball joint separator fork. You might want to do the stabilizer bar links at the same time if they're rusty.
I can't wait to get the car on the road to feel the difference in the ride.
Pulled the lca today and the rear bushing just fell off! Bought one from pick a part to see if that was the problem...and BAM! steering is tighter....little vibration from drivers side lca (replace tomorrow) man what a difference...night and day...thanks everybody!
glad to hear, and thanks for reporting back... I'm about to embark on the same journey. Did you use/need air for the LCA? Only have hand tools here and hoping to tackle. Car is also surface rusted underneath pretty decent...
you'll be fine with a breaker bar, if it's rusted like that tho I'd recommend a healthy dose of pb blaster before attempting to break anything loose
I used a breaker bar and 2 foot piece of pipe..took a little longer...but i got it done..ball joint nut was the hardest...couldnt really determine the size 19 or 18 mm...but i got it off with the 18...end links were a snap as well...did stabilizer bar bushings as well...thanks again everybody...she rides smooth again
