99 Engine removal
99 Engine removal
Good Evening:
So my engine is leaking oil like a sieve. I replaced the rear valve cover gasket with no luck. I'm thinking it is the timing cover. I'm looking to pull the engine to change the real seal too.
I have seen a couple "post it" type write ups for removing the engine. I just have a question.
Do I need to pull the engine with the trans (auto) or can I separate the engine and trans to pull it?
My car was leaking a bit of oil for 2 years until recently I fixed it, It was mainly the timing chain covers, everytime I was driving, oil was splattering everywhere so I had to limit my driving until I got it fixed, What stopped the oil leak my mechanic replaced the following..
Timing chain covers
Both Valve Cover gaskets
New oil pressure switch
New knock sensor (optional, I had the part but he went ahead and replaced the old broken one)
New oil pan
Clean off all old oil
and of course put in new oil.
now Not even a single drip onto the ground.
Timing chain covers
New oil pan
The motor does NOT require removal in order to remove the front cover.
Do some searching.
There are some good threads and some related YouTube videos.
It's a bit of a hassle and logistically a PITA but not technically difficult.
But less of a hassle, less of a PITA and less technically difficult than pulling the motor.
Do some searching.
That piece of info is a great help. Now knowing I can take the front cover off with out pulling the engine I may go that route. I have no problems pulling engines but there are so many sensors and connections on this engine. I'll search more on just pulling the timing cover. Thanks for helping this Maxima noob.
Just as an aside for the future. Does the engine have to come out with the trans attached or can be split.
Have you looked at your PS pump return line hose? That usually leaks too. That hose gets really brittle and hard at the end and fails to keep fluid in even if you replace the oem clamp with a worm clamp. This is an easy fix.
I suggest you by some uv dye, uv flashlight, and yellow uv goggles to make sure you actually locate the leak. And make sure you clean up the engine of dirt and grim to help locate the leak better. I didn't do this first and looking back now, I might have not had to remove my rear/front timing cover at all. Most of the leaks were contributed by the rack and pinion and that return hose leaking onto the exhaust.
03-12-2020 12:06 AM
CAN-Toronto FS: E-Manage Ultimate and patch cable
knight_yyz
10-24-2015 08:05 AM
