Radiator fans
Radiator fans
Noticed car heating up yesterday...got to poking around a little and found both fusible links blown...looked a little further and noticed melted wires coming out of fan motor...motor locked up completely...wires melted all the way to the plug! Trip to pull a part...complete fan assembly $20...spliced in new plug installed fan motor and fuses and all is good! Easy job!
Low speed side
I may have been a little fast in saying they work again...a/c on...they work fine....a/c off they won't come on...fuses/relays are good...both fans do work...CTS possibly? Code scanner shows temp at 214...fans should have came on right?
The fans should operate on low speed between 207deg and 220deg.
Above 221deg, the fans should operate on high speed.
Do you know if the fan shroud/assembly will swap over too?
I verified exactly what you said, and you're 100% correct that the wiring is swapped between the A33 and A32.
All others 203º to 221º F for the low speed range
Maxima - 95, 97, 98, 99, 2000, 01, 02, 03 plus
i30 - 97, 98, 99, 2000, 01
i35 - 2002, 30, 04
Unclejunebug
04-02-2016 05:42 AM
RWCreative
09-21-2015 11:01 AM
