O2 sensor question
O2 sensor question
I am installing a new custom exhaust system. The folks who made the catback exhaust pipes, Mandrel Exhaust Systems (recommended by Maxima.org members), also built me a pipe with a bung in it for the O2 sensor that is directly behind the cat. The other end of the pipe will go into the resonator front end.
In order to get it to all fit, I asked them to slant the bung 45 degrees. As I look at it while test fitting, it appears that the tip of the O2 sensor only sticks out into the exhaust stream about half way. All the little holes in the tip are still exposed but they just don't sit in the stream of the exhaust flow.
Do you guys think that is going to be a problem or will the exhaust flow still get into the little cranny enough for the O2 sensor to get a good reading?
That O2 sensor's purpose in life is to make sure the cat is working. That's it. It doesn't influence the air-fuel ratios like the primary O2s do. The primaries are the first O2s seen by the exhaust as it leaves the combustion chamber from each bank.
If no DTC is generated then your car is none the wiser and at least "thinks" it's happy.
Excellent thinking
Thanks guys!
Oops, I missed your reply earlier
It will be, uh, good enough
With a little custom work ...
I wanted to report that I was able to do some tin work around the heat shroud above the catalytic converter so the O2 sensor fit great. The car started and ran well and passed emissions testing fine. It took awhile to get the car running well though due to some fuel injector issues but now that is all behind me and the car is really fun to drive. Thanks again to all the Maxima.org members.
sdotcarter
09-02-2015 09:53 PM
