problems with 95 max! please help
I was wanting to check the trans drop resistor with an ohm meter and I was wondering how to do that?
And I have 8 codes
P0325
P0180
P1441
P0105
P0443
P0446
P1105
And the o/d light flashes 17 times when car is first turned on. The trouble I am having is that the car will rev up to only 2500rpm sometimes but it shifts hard and won't really go above 4000rpm no matter how much throttle you give it. It also idles at 700 until you drive it a little. Then it idles at 900-1000 and it can tell it's too much when you bucks when you put it in drive. Thanks for any help!!!!!! Here's my video on YouTube https://youtu.be/6pVWygy8WiU
And I have 8 codes
P0325
P0180
P1441
P0105
P0443
P0446
P1105
Time for an overhaul... Map sensor, absolute manifold pressure sensor(is on idle air control valve right?) Is probably a good chunk of it. After that I would go for egr, and evap systems. I'm not familiar with how fuel temp sensor effects performance.
Youtube has good instructions to fix your issue. Also do a search in this forum.
Most of us do not know the codes by heart. If you would also say what the code says, you might get more help. I mean something like this: 0325 - knock sensor.
1441 evap emission control system small leak
0180 fuel temp sensor "A" circuit malfunction
0105 MAP circuit malfunction
0443 Evap purge valve
0446 EVAP canister vent control valve
1105 MAP/BARO pressure switch solenoid valve
update
Still have the shifting problem and would really apprectiate some help. I was gonna dump the charcoal canister, crawled under there and looked and did not see it. Noticed under the hood there was 2 or 4 holes where some EVAP equipment belonged. the whole evap system has been removed so I guess I don't need to worry about those evap related codes. please please please help lol
so your name's brian and you have a 95?? hmmmm, me too!!! man, and i thought my 95 was messed up, compared to you i have a like new car!! what color is it??? if you say dark blue then i'm going to be needing to see some pics!!! i haven't seen a list like that since i went grocery shopping earlier this week. gl
My last name is Bryant and mine is green. And the last three codes can be thrown out because they are evap related and they removed the entire evap system
pktaske
05-06-2016 07:49 AM
pktaske
09-04-2015 08:40 AM
