1997 Maxima AC Pulley Removal
Old 11-23-2015, 06:23 PM
surfin_phil's Avatar
Hi
I need to replace the AC pulley/clutch bearing on a 1997 Maxima.
Got the center bolt out but am stuck now.
Clutch won't come off. Am I missing something? I thought that part should just pull off by hand.
Any advice is appreciated>
Phil.
surfin_phil is offline
Old 11-23-2015, 08:56 PM
DennisMik's Avatar
The pulley does not just pull off by hand. You need to use a puller.
Here is a link to the service manual for the pulley removal. Go to page 133.
http://boredmder.com/FSMs/Nissan/Maxima/1997/HA.pdf
DennisMik is offline
Old 11-23-2015, 09:24 PM
Thanks Dennis
I guess I will be making a tool.
Do you happen to know a source for the bearing?
Phil
Old 11-23-2015, 10:39 PM
you can rent the tool from Autozone for free...
The Wizard is offline
Old 11-24-2015, 07:05 PM
OK, got the clutch plate off and the pulley is sloppy on the shaft.
Bearing rolls fine but slides on and off the compressor very easily and is floppy. Looks like the shaft/housing the bearing slides onto is worn smaller.
Does that mean a new Compressor?
Phil.
James92SE
Forced Induction
04-21-2016 06:59 PM
James92SE
04-18-2016 09:43 AM
NoJoke25
11-01-2015 07:19 AM
maxima297
18
10-27-2015 10:29 PM
dbacks
10-27-2015 02:56 PM
Quick Reply: 1997 Maxima AC Pulley Removal
