vibration in gear while stopped.
So I have vibration in my steering wheel when Im in gear and stopped reverse drive, 1, 2 same thing vibration goes away if Im in park or neutral. Car also feels like theres a occasional little putt.
My Rpm while stopped is around 650.
Theres no shake from stopping its only occurs when in gear and stopped. 1999 maxima se built 01/1999
Could a vacuum leak cause the shake?
I've replaced spark plugs, a coil, and timing chain tensioner shake was there be for I did all this work.
A coil? Check readings on all coils. And inspect their boys for cracks.
Put a flat head screwdriver end on the plastic part of injectors and your ear on the screwdriver handle, listening for ticking.
Which brand of spark plugs did you install?
valerit1
05-19-2016 04:13 PM
ZerotoSixty
29
02-29-2016 05:13 AM
ColdCananda
02-16-2016 03:50 PM
ehunni7989
02-15-2016 02:56 PM
