Stalling problem..
Stalling problem..
Just brought a new MAF and EGR valve. Do you guys think this would help my stalling problem? It sometimes cutt off when i first go to start it. It stalls randomly when im driving. Replaced the fuel filter already. I have no idea whats going on. Please help. 97 MAXIMA SE
Mine would stall immediately after starting it. Wouldnt idle longer then a couple second. But if i gave it gas it would stay on. Ending up being one of the egr valves. The back pressure one. I deleted the egr n she runs fine now.
egr code is the solenoid, sensor that goes into the guide tube or guide tube needs to be cleaned. new maf should fix your stalling issues, but a cleaning might help if you haven't already. OEM junkyard maf is reccomended over aftermarket. Why don't you start by pulling the codes and researching from there instead of throwing parts at the car?
Either way egr will affect mpg more than engine performance so I would worry about that last. Your bigger issue is with the maf.
You can pull the codes yourself using the screw method on your ecm or whatever its called located behing a panel on the right of your gas pedal. Very easy to do. Yes clean the egr guide tube. Theres no point in buying a new one. But I would worry about that last. I have had mine blocked for about 1.5 years now and I'm not worried about it. Worry about your maf. Spray maf cleaner in it and see if it helps. Do not clean it with a cloth just spray it. Likely it won't and you'll want to find yourself a used maf from a junkyard but if you already have a new one just use that I suppose.
Just saved me some money lol.
valerit1
05-19-2016 04:13 PM
Dany
09-04-2000 07:51 AM
