Check engine light came on
I took my 95 Maxima to Autozone to have them put their code reader on my car and was told they were unable to. THey also told me that it does not start with Maxima until 96 when they can put code readers on the car. My question is "Now what do I do?" IF they are unable to put a code reader on my car how do I find out what the check engine light is telling me?
Would an OBD1 reader work? Thanks in advance for any help you can give.
Could someone tell me where the connector for the reader is on my car? The reader the autozone guy brought out had a connector on it that would not fit my car. The only connector on my car that I could find is under the fuse box under the steering wheel.
Its on the passenger side behind the console.
buy your own scanner and do it yourself, this is the one i have, clears codes, works great https://www.amazon.com/Oxgord-Scanne...=obd+2+scanner you have to have the max running in order for it to work.
Just check the codes yourself: http://vbxmaxima.8m.com/ecu.html
Then use this to decode: http://vbxmaxima.8m.com/ecudecoder.html
Further info on codes here:
https://maxima.org/forums/4th-genera...ere-first.html
valerit1
05-19-2016 04:13 PM
slickblack94
02-29-2016 10:33 AM
Kevin1960
02-17-2016 07:45 PM
11-06-2000 11:54 AM
