Bend heads
Have you done a block test? This helps determine if exhaust gas is entering the coolant system.
Did your car overheat? What make you think that you have warped heads?
I allredy opened the heads and found blown head gaskets.
Yes there was a milk when i opened the oil cover.
And there was some kind of foom coming from the radiator it looks like a saop foom.
And yes i got my car over heated unfortunately befor all of that.
My mechanic said that i have a warped heads.
What if it was modified with low compression pistons and rods and cams for turbo project ? of couse you dont want to loose that.
That is why im asking if its affecting the cams or not. I have a good block and pistons. But heads are bend and head gasket is blown.
Replace heads? Or re machine them?
97_GXE
09-20-2016 02:37 PM
