98 manual transmission leak, any ideas?
My 98 maxima's 5 speed is leaking from the seal where the shifter enters the transmission. It has been changed three times, and it is starting to leak again. The first a burr was found on the shaft, my mech smoothed it out and put in a new seal. It started to leak again, and he had found a small tear in the new seal so he replaced it. It started leaking again, so I brought it to a transmission guy. He said he found a tear in the seal, so he replaced it again and used tephlon tape. It held for 2 weeks and started to leak again. He said that Nissan no longer makes that area of the tranny case so in order to replace it, he would have to find a used core that hopefully didn't leak. Anyone have any ideas on how to stop the leak or would it be worth the time to put a 02 6 speed into my baby. Thanks for your suggestions.
My guess is that the burr in the shaft is still there, causing the tear.
If I'm correct, the cure might involve removing what is left of the burr.
Mike - Bromance Racing
01-05-2017 11:50 AM
Chdmorrison
07-12-2016 11:28 AM
