rewiring corner lights
Old 08-21-2000, 09:58 AM
tunedup's Avatar
so that they will b brite as if i was signaling
tunedup is offline
Old 08-21-2000, 12:08 PM
Wizeguy's Avatar
I'm assuming your talking about a 95-96 Maxima, as they have dual filament bulbs in the corner lights. You can take the bulb out then sand off one of the posts on the side. Push the bulb back into the socket turned 180 degrees. Tada...
Wizeguy is offline
Old 08-21-2000, 12:18 PM
Jeff K's Avatar
If you blow the fuses..>
there are two under the drives side panel and in the engine compartment on the drivers side is one more.
I tried and blew-out some fuses. When the fuses are out so are your taillights.
That is if you try this cool Wiseguy short cut, you might need the above information. :P
Jeff K is offline
Old 08-21-2000, 12:41 PM
Slickismax's Avatar
It's dual filament on all 4th gens.
EricGP has a 97, and we did his. The wiring harness is actually a dual filament, they just don't have a wire soldered into the brighter filament conncection. Since you are re-wireing your conrers, why not do your turns also? On my car, my corners are bright all the time, plus my turns stay on constant, so they match my side markers, and they blink brighter. If you want to do the turns also, give me an email and I'll send you info.
Slickismax is offline
Old 08-21-2000, 12:47 PM
Wizeguy's Avatar
I agree with slickmax too. His way is more permanent and professional. Both ways are will work just fine.
Regards
Wizeguy
Wizeguy is offline
DJLAX152
05-04-2021 11:46 AM
fastcarny
10-06-2015 10:42 AM
Maxie40
09-14-2015 11:28 AM
-ReLLiK-
09-08-2015 12:02 PM
Maxima30
09-07-2015 06:13 PM
Quick Reply: rewiring corner lights
