235/45/17- tire pressure?
I having been trying to search for a while and could not find it, so my question is What is a good tire pressure to keep on the 235/45/17 tires, for daily driving and some street racing any way thank for any help.
__________________________________________________ _______________
1998 Maxima SE
17"Racing Hart s-15
Jwt intake
apexi N1 muffler custom catback
RT High Flow cat
5%tint
front Strut bar
2 12" Polk Audio Subs with Kenwood 600 watt apm
Aluminum dash kit,
(intax springs and KYB on the way.)
1998 Maxima SE
17"Racing Hart s-15
Jwt intake
RT High Flow cat
5%tint
front Strut bar
Aluminum dash kit,
Re: 235/45/17- tire pressure?
30 psi for my current setup is way too low and overfilled for my stock ones.
I assume you are talking about me?
Yes it is harsh. Harsher than the stock tires but thats what you get when you combine an SE + low profiles.
If you leave the tire pressure too low eventually you will dent your rim.....
If you want low profs with a smooth suspension you should spring for the AGX shocks.
Are u sure about this because the guy a the tire shop told me to keep it between 40-45 thats why i asked u guys> i know the factory is 34 psi for the nissan se stock wheels and tires. when mine were at 35 psi the tires seemed flat the front one atleast.
Fronts will always seem flat. Like I said take a look at the side of your tire take about 4 from that and you should be fine.
Your tires are low profiles and the manual does not apply in this case. Listen to the guy at the tire shop.......
06-06-2017 02:01 PM
