2 those with the Stillen Hi-flow intake ...
Did u guys reset your ECU?
I initially didn't & felt that there was no improvement over the stock intake ... in fact .. I thought there was a very noticeable deterioration of low-end torque & only minimal gains in hi-end
well .. 2nite I reset my ECU & took the car out 4 a spin ... maybe it's purely psychological .. but my butt dyno says there is a significant improvement from before resetting my ecu ...
However, I can't really tell if it's better than stock ... but dyno's that have been published b4 state that it is ...
The sound alone makes it worth it
If u haven't reset your ECU after installation .. u mite want 2 consider it ... all u do is disconnect the battery for an hour ...
Originally posted by LoveSick
After cleaning my filter, oil change and stuff, I just reset it. Will try it out tomorrow morning!
Originally posted by yo_its_ok
Butt dyno...LoL...
anyhow air intakes don't make HP, but they provide something that people mistake for HP, and that is acceleration.
RPMs climbing quicker obviously you'll feel as tho you've gained some "power."
Lots of gimmicks out there, seat of the pants driving or a dyno-nut.
-Just Drive Dammit.
Butt dyno...LoL...
-Just Drive Dammit.
regardless .. the sound is kewl
Can you clarify what you mean by this? I dyno'd 6 HP higher with a cone intake on.
Butt dyno...LoL...
-Just Drive Dammit.
Butt dyno...LoL...
-Just Drive Dammit.
Butt dyno...LoL...
-Just Drive Dammit.
Butt dyno...LoL...
-Just Drive Dammit.
Re: i'll give it a try, but....
Originally posted by tb420
do our stereos have a code lock out number that we have to enter when re-connecting the battery? (base level lame-a$$ amfm casette stereo in my car)
Originally posted by mbcp_tdogg
Can someone take the time to explain how the ecu works and why resetting it after certain mods is beneficial? Couldn't find anything with search. Thanks.
Thanks UMD.
Sigh, ignorance is bliss. The more I learn, the more I want to add on.
Originally posted by UMD_MaxSE
The ECU is adaptive to a certain extent. Thus, things like an increase in airflow in and out of the engine will cause the ECU to adjust the engine's running parameters. When you add mods like an intake or y-pipe, you will have more airflow. Resetting the ECU in essence, 'deletes' the old settings it had stored before the mods. After a reset, it will measure the engine parameters again and adjust better then it would without a reset.
One rebuttal. My Accord laid down 242hp @ wheels w/ heavily modded H22 motor. However I laid down a mid 13s 1/4 mile time. First time at the track, after 5000 miles of breakin in, and street racing. Someone thought I was juicing, so I had to show them no juice, no cheater 5lbs tanks.
The secret of that acceleration is in how quick my rpms climbed. Of course off the line you get torque to get you started, but when the rpms started climbing with a vengence, and on the VTEC cams from 3200 instead of 4800 all the way to 7800 redline, thats freakin fierce acceleration. On the street, you feel it, but at the track it was proven.
]Originally posted by yo_its_ok
Wow a feeling, a vector force pushing against you, what does that prove ? Higher velocity, yes. That's it.
You can say that is HP or Tq, however, you think about it then. You go to a dyno, and see minimal gain in hp or tq, you ask why ? The engine sucking in air makes anyones blood pump, and the butt dyno experiences something its never have before. The RPMs are climbing quicker to reach the power, but at the same time, it builds up so nicely, it plants your butt in your seat, and it feels great.
As for your End of Story remark....It ain't over baby...
Let me ask two questions:
1. How do racers calculate their optimum shift points?
They do it by calculating the torque at the road (factoring in all gearing). You always want to maximize your torque applied to the road. This provides the best acceleration.
2. When you punch your car at 2500 rpm, where does your car feel like it's accelerating the hardest?
I guarantee you that it is much closer to your torque peak of 3700 than it is to your HP peak of 6600. Just about everyone on this board will agree that their car doesn't pull as hard near redline.
Basically if you are accelerating harder, you are making more torque (which means more HP because I'll state it again: HP = torque * rpm / 5252).
why didn't someone tell me this!!
I have an intake and a y-pipe and I never have heard a thing about resetting the ECU....I'll do it today and see what happens. Also, why does it take an hour to reset? I would think it would do it instantly....
Desert Pearl, oi man...it's an intake we are talking about. Do you honestly think its Tq or hp the filter makes, and thats why the car feels faster ?
Its like you went on a totally different tangent with throwing formulas, and so forth.
Geez. Well anyhow, butt dyno or not, all it is doing is just climbing quicker to propel the car, and your idea of its creating more torque, simply, if it gets to that fat part of the power band faster, then, you feel as tho you have gained power. Acceleration times have decreased, but your power has gained marginally.
Thats all I'm saying.
One more thing...
BTW my peak torque on my H22 was 202lbs-ft @ 6900.
peak hp @ 7100 just before 7800 redline.
202ft-lbs at 6900rpm equals 265hp, which is more than the peak HP you claimed earlier.
As for the actual #'s vs your formula #'s prove it on a Maxima, then talk to me about it.
http://www.g-speed.com/pbh/torque-and-hp.html
As far as actual numbers go, here are the results from my last Maxima dyno run.
rpm / torque /actual hp/ calc hp
3000 / 158.3 / 90.4 / 90.4
3250 / 165.9 / 102.6 / 102.7
3500 / 171.2 / 114.1 / 114.1
3750 / 180.1 / 128.6 / 128.6
4000 / 179.0 / 136.4 / 136.3
4250 / 179.3 / 145.1 / 145.1
4500 / 177.9 / 152.4 / 152.4
4750 / 178.3 / 161.3 / 161.3
5000 / 172.8 / 164.5 / 164.5
5250 / 171.9 / 171.8 / 171.8
5500 / 170.1 / 178.1 / 178.1
5750 / 166.8 / 182.6 / 182.6
6000 / 162.0 / 185.1 / 185.1
6250 / 156.0 / 185.6 / 185.6
6500 / 150.5 / 186.3 / 186.3
The calculated values match the actual numbers except for rounding error. Here are numbers from my Eclipse also:
2250 / 84.2 / 36.1 / 36.1
2500 / 126.3 / 60.1 / 60.1
2750 / 151.1 / 79.1 / 79.1
3000 / 177.7 / 101.5 / 101.5
3250 / 207.9 / 128.7 / 128.7
3500 / 230.9 / 153.9 / 153.9
3750 / 241.9 / 172.7 / 172.7
4000 / 243.5 / 185.4 / 185.5
4250 / 247.9 / 200.6 / 200.6
4500 / 248.1 / 212.6 / 212.6
4750 / 254.4 / 230.1 / 230.1
5000 / 253.9 / 241.7 / 241.7
5250 / 250.4 / 250.3 / 250.3
5500 / 237.7 / 248.9 / 248.9
5750 / 234.1 / 256.3 / 256.3
6000 / 226.5 / 258.7 / 258.8
6250 / 210.9 / 250.9 / 251.0
6500 / 207.9 / 257.3 / 257.3
6750 / 197.0 / 253.2 / 253.2
7000 / 188.4 / 251.1 / 251.1
7250 / 178.8 / 246.9 / 246.8
7500 / 168.1 / 240.0 / 240.1
7750 / 156.3 / 230.6 / 230.6
These also match +/- rounding error. You can see that on both of these the torque and HP are almost equal at 5250rpm like I mentioned earlier.
Anyhow, please check out the link above. It explains everything and is most educational.
Omaeeeee....u need a better hobby
I see you changed the pic in your sig. I kinda liked your pic of the taillight and side of your car....
I just put in my Stillen Intake today and drove around a little and didn't feel much of a difference. Then i came home and unhooked my negative battery cable for 2 hours and then drove the car. It felt a little quicker, but what i am really impressed with is the sound. IT SOUNDS SO COOL!!! Greatly anticipating my stillen y-pipe :-)
01 se 5 speed sterling mist/frost leather all options
josjua tree aluminum dash kit, F/R clears, Piaa plasma h4's and h3's. AE shift **** and sills, Stillen Intake and the Y-pipe is coming soon.
