2002SE AUX switch w/ 6CD Changer
#41
http://www.harmankardon.com/drive-1/wired_fm.aspx
#44
From reading the owners manual, the usa-spec should simply plug into the existing wire harness. On the 5.5 without the external changer, their is no need for a cd changer button. To activate the usa-spec, simply push the cd button, then switch to cd #6 track #1. This will give you direct connect. Their is also an option to control the ipod through the stock head unit.
I will be purchasing one of these today.
#45
I've got the '03 Bose w/6-disc changer in dash.
I bought the Neo Prolink v2 (which looks identical to the AUXNISSv3). After spending 2 hours with a Best Buy service tech and 2 phone calls to tech support, we've concluded that it's not possible to connect an iPod using any of these adapters.
Unlike the '00-'01 Bose w/trunk changer, the '02 & '03 don't have the aux port needed to connect anything to it. The most frustrating part is that the tech support line swears it should work, but they seemed to know about as much as an outsourced phone operator reading a script. I plan to call Monday for a refund.
I'm interested in learning more about the FM modulator. Is that a direct connection; if so, how? There are only 3 ports on the back of the HU and they're all used.
Thanks for the info about the non-functional adapter
#46
see my link above...the wired FM modulator plugs in to the "antenna in" on the HU
#47
#48
#50
1st post. I have a 02 bose factory HU W/ nav system, CD changer in truck but does not work. Has anyone tried the USA spec PA 11 with this set up. Crutchfield filters this unit out of seaches for my car b/c of the GPS, but with the CD changer input I think it should work? Anybody have any thoughts?
#51
HOW???
What if, in my case, your cd player cuts out and your tape deck doesn't work and you have an mp3 player not an ipod and you want to directly connect that to the 5.5 BOSE HU .... Now how do you do that! LOL tricky...although I sacrifice not having my cd player or tape deck to not work at all is there a way I can not use my cd player, or tape deck, but hook something else into its port or is it all one unit? Or would it be best to hardwire an fm modulator to the stereo? Any suggestions?
#52
usa-spec
The usa-spec adaptor did not work on my '02 GLE with the indash 6 disc. There are three connectors on the back. Two fit, but the third does not. It should work on the '04-'06's however. If any one is looking for one, I have an extra laying around for sale.
#54
#55
I have the PA11-NIS for my 2k and it works great, great sound quality etc. I just purchased it for my wife's 5.5 with the in-dash 6cd and one of the connections doesn't fit. If anyone knows if there is a way to make this work, it would be much appreciated.
#59
03 GXE
Everyone here is talking about Bose system. I have a non-Bose system with 1 CD (no 6 CD changer). I am planning to get Neo Pro Link - PODNISV2 or USA Spec PA11-NIS. Neo Pro Link - PODNISV2 is my first choice.
So, Do you think there is a CD changer connector which I could use for these adapter or is it all 03 is just not going to work?
#60
try this, its called the dice. my friend has it, works pretty well. www.diceelectronics.com
#61
#63
#64
USA SPEC works but doesn't charge IPhone 3G
After lot of research, I found this. Neo Pro Link is fake (http://www.my350z.com/forum/4905138-post8.html) considering the guy the telling the truth. Anyway< so I bought USA Spec PA11-NIS. Will get it next week.
#67
You need to get a different cable about $20 that you replace your existing ipod cable, and it will charge your 3G iphone.
AaronL
08-08-2020 10:31 AM
worldwiderecognized
09-30-2015 01:16 PM
HerpDerp1919
09-29-2015 02:02 PM
