Upper intake removal
Old 09-01-2009, 06:48 AM
  #41
sontakke's Avatar
Originally Posted by Professor
None of the above, i unhooked the battery, left it sit like 6 hours, hooked it up, car would barely run or idle, no power, backfiring thru the intake, it was bad, limped it home and ordered a new MAF, let the battery unhooked for 8 hours, installed MAF, fired right up, purrs good, drove it, feels like a new motor, no pinging or hesitation, so far so good, iam going for a ride now and gona hit some steep grades and see if it pings, if not i beleive it was the MAF the whole time.
If you have been here long enough, you would have known that MAF is the answer almost all the time for Maxima driveability problems. We could have auto-robot replying to any topic with "it is your MAF" and he would be right more times than not :-)
- Vikas
sontakke is offline
Old 09-01-2009, 06:51 AM
  #42
Old Fuddy Duddy
Colonel's Avatar
....if not i beleive it was the MAF the whole time.
DOH!
Colonel is offline
Old 09-02-2009, 06:00 PM
  #43
Professor's Avatar
Rub it in now
Light came on today........O2 sensor near firewall is toast, guess from running lean for so long it killed it.
Professor is offline
Old 09-03-2009, 07:50 AM
  #44
sontakke's Avatar
Rub it in now
I am going to be brutally honest with you. You have got P0430 code. Against all the advice given in this forum, you *will* go and change that O2 sensor. When the light comes back on again, you will be here screaming your head off.
Am I right, or am I right?? :-)
Seriously, what code are you getting? And this time at least listen to input from others.
- Vikas
sontakke is offline
Old 09-04-2009, 06:08 AM
  #45
Professor's Avatar
- Vikas
Not once have i mentioned a P0430, i dont know where you got that but thats not the code i have. I had lean codes P0171 and P0174, i replaced the maf it all went away, came back on, P0138 and P0139 the O2 sensor crapped out. So yes, iam gona change that O2 sensor.
So I hate to say it but your not right.
Old 09-04-2009, 02:36 PM
  #46
sontakke's Avatar
You are right, you did not mention which code you got after changing MAF. P0138 and P0139 is saying bad rear O2 sensor. However, before throwing new rear sensor, you should rule out other causes such as lose wiring, bad ground etc.
- Vikas
sontakke is offline
Old 09-05-2009, 07:22 AM
  #47
Professor's Avatar
- Vikas
Ruled out, besides its the oem one with 145k on it, ive replaced the front one 2 years ago, its time. $70 for a Denso one iam not gona complain.
Old 11-02-2009, 09:51 AM
  #48
tbergma1's Avatar
I didnt think it would be the knock sensor, it it was it would retard the timing and go in safe mode as not to advance timing too far. I have seen so many problems cured by the infamous MAF.
tbergma1 is offline
Old 11-02-2009, 01:45 PM
  #49
mandyfig's Avatar
Sorry for my ignorance MAF means Mass Air Flow sensor?
mandyfig is offline
Old 02-26-2010, 04:08 PM
  #50
RR5
RR5's Avatar
Yup. I've got driveablity problems past 1st gear just before 4,000 RPM. Got a used MAF on the way and fuel filter.
Professor, sorry to bump the old thread but did the new oxygen sensor resolve that DTC?
Edit: I'm not 100% sure its the same for the 2000 Maxima but for the 2002 Maxima Standard plugs are PLFR5A-11 and 4A is hot type, 6A is cold type.
RR5 is offline
James92SE
142
01-02-2024 09:23 AM
bumpypickle
09-20-2015 08:22 AM
bumpypickle
09-19-2015 01:07 AM
Mahmuth
09-17-2015 11:45 AM
Maxboy23
09-09-2015 10:37 AM
Quick Reply: Upper intake removal
