Turn signal and hazards no longer work
I was driving home from work one day, and while driving, suddenly noticed that my headlights and dashboard went out for a split second, and came back on with the air bag light, which dissapeared a few seconds later. After this incident, my turn signals and hazards no longer work.
They sometimes work for short periods of time (10 minutes or so) when I change it's fuse in the relay beneath the steering wheel or if I play with the turn signal bulbs a bit (remove them/change them around) but other than that, they don't work.
What steps should I take to get them working again? Anything would be helpful .. this can be potentially very dangerous on the road.
Hey guys I just bought a 00 Max and have the same problem. What exactly needs to be done once I get to the relay? (I know absolutely nothing about this car.....yet)
Please help me out. As mentioned above, this is very dangerous.
I should also note that I checked all the fuses and everything checked out. so...what exactly is the relay and what did you do to fix it? I'm scared to take stuff apart...like I said I dont know much about the car yet. Literally just purchased today.
Thanks again for any help.
i have same problem i keep blowing fuses signal and hazard.i change fuse and flasher from dealer still blow it out. i check for short in harness found nothing. i order new hazard switch i get on wednesday? help me please
^^ Happened to me awhile ago. I replaced all the hazards/turn signals fuses and all the turn signal bulbs and then everything was fine.
but for some weird reason my car doesnt flash the hazards when I lock, anybody know how to fix this?
Led turn signal bulbs
I just installed front 1157 and 1156 led turn signal bulbs, with a led flasher relay, i turn my dimmer switch down, and now when i use the turn signal, my lcd clock on dash, and a/c contol display lights flash. What am i doing worng or what i can fix?
Bulbs are where there suppose to be, havent checked the fuse, but the turn signals wouldnt work if it was a fuse, also to add, my rear turn signal led bulbs stay on, i have the 1157 led up front and the 1156 in the rear, and a new led flasher relay, and tips?
trasmadean
02-01-2017 08:20 PM
03VQMAX
10-02-2016 09:36 AM
jerrod99_se-l
08-27-2015 08:27 PM
