Identify the Rusting 5.5 Gen Maxima Part (Fun for All Ages!)
#41
Next car I buy that I plan to mod, I will not drive in the winter.
#42
I also will never be buying a Nissan again. This is my first and last Nissan product. In the past year, the repair bills have exceeded my monthly payments. And now the exhaust system is falling off, yet another repair bill.
Plus, the fact that Nissan and Infiniti dealers treat each other like they've never met pisses me off.
#43
If a cars treated like Shi^ it's gonna return the favor. PERIOD.
#44
Im not really talking about engine parts because I expect those things under the hood to rust some because they are not treated. Im talking about body panels that bubble up and rust. The cars im talking about had rust on fenders, the roof, etc which shouldnt be on a 5-7 year old car "IMO". I expect rust on cars 10 yrs plus but I guess if your car was built on a friday or a monday makes a difference.
#45
Holy rust batman!!!!!!!!
But seriously your car looks like you pressure cleaned the engine with salt!
My maxima was in ny for 12 years and isn't rusting that bad.
GL my friend!
GL my friend!
#47
#48
#50
I agree BLAME NISSAN FOR THE RUST. It is thier fault. I had a 91 corolla that had way less rust than my 02 max... My uncle helped me do my headers and rust was our biggest setback by far. He kept calling the car a rust bucket (7 year old car should not be a rust bucket)
I also had my oilpan rusted and leaking a few months ago and that should not happen. A couple mechanics were confused when I said I had to replace the oil pan. They said they had never ever had to do that because they shouldnt rust like that. Nissan uses cheap metal and even cheaper coatings (if any)
#51
#52
They don't usually strip. The heads break off instead. So far I've had pretty good luck getting bolts out despite the rust. You just keep the PB Blaster handy and take your time working the bolts out.
I had to work on the main drive belt tensioning nut for several hours to get it to turn freely last year when I replaced the belts. That's a horrible design for a nut. It's open on the top so water / moisture can get in with no way out. Brilliant!!!
#53
In light of this problem, I decided to check mine out. It was pretty bad so I thought Ok, no problem, tremclad to the rescue. I started scraping off the rust and the friggin pipe sprung a leak!!! The damn rust was holding the coolant in the line
#54
But, pretty much as soon as I touched it, it started dripping. The rust was certainly holding mine together.
#57
yup, for now. I refastened what was left over and tie wrapped the hose to the pipe. It will get me back and forth for a day or two. Only reason they used pipe was because it is close to moving parts. I'll take a pic when it goes back together. just for ****s and giggles
#58
How many miles/km on these rusted out pipes/oil pans? I've got an '02 I35 and there's no sign of scale, just a little surface rust on the coolant pipe. The oil pan is still almost all black with little rust. There's also no rust on the body. I'm north of TO. Canada. I've got 114,000 km/71,000 miles on it. It has been rust sprayed, but I don't know how often. (Just bought it 6 months ago).
#59
I have just over 200,000km's on my 2002 Maxima. I purchased it new Feb 28, 2002 from 401 Dixie Nissan and imported it into the US myself. I'll have to take a picture or two of the part I took off the car. It's pretty bad.
I had to replace my oil pan last year because it was rusted through and dripping. I haven't done any sort of rust proofing or prevention on the car.
#60
I have 205 K on the car, but the engine was swapped under warranty at about 130K so I am not sure if this pipe came with the new block or not. My pan looks fine except there is a small dent where I bottomed out on something a few years ago
#61
So, today I sprayed rust inhibitor in the hole and stuck a plastic cap over it. The cap came off a 5/8" copper refrigerant tube. It fit perfect, (nice & tight). So I hope that when the time comes it will move freely.
#62
I also put a plastic cap on mine after I changed my belts. Hopefully should I ever need to adjust it again it will spin freely.
#66
Ya man. That's ugly. Come spring, I'll be taking a wire brush to mine and layin' on the rust paint. I've been spraying the crap out of areas that are starting to show signs of rust with Rustcheck, ( a Canadian brand of rust inhibitor redily available).
#67
this is a common thing on Nissan's, i'm on my third maxima right now, having owned a 1985, and 89 SE, working on the car always had me spilling blood, when working on it. for some reason the bolts rust real bad, and sometimes the bolt heads snap off. i dont know how many of you guys experienced this, but rats use to eat through the ignition wires, and even the injector wires. but living in Cali now and not seeing any snow, i guess it's a good thing, no worries of rust here, Arizona is my next resting place, so the its the sun and my paint job to worry about now.
as to the comparing of other cars with rusting, I've also owned Acura Legends, Sedan and coupe. the sedan was a New York car, the rear quarter panel rusted through, which is a common thing on Hondas in the Northeast, the coupe i bought in VA and drove to Cali, and after 3 years of owning it since 73K, and selling it in July with 100K, rust was never an issue with it even though it was an East coast car originally purchased in PA back in 95.
#68
Continuing the rust saga...
My car got rear ended (not real bad) last week so it's at the body shop. I had them take a look at the rust on the roof of my car by the windshield because I knew that area was pretty bad. I could see visible scaling and cracks. The short version is that it's gonna cost almost $900 to fix that area (assuming they don't break the windshield and can re-use it). They told me it's right at the point where if it's not fixed they expect it will start leaking shortly.
Nissan strikes again!
#69
That's why you have under carriage car washes....I took care of my Civic that way in Chicago. Once every 2 weeks, have to do an undercarriage wash.
But have been living in ATL for ~20 years now....relief!
#71
This is nothing, just wait until your foot goes through your floor board(plywood fixed this), rear control arm snaps, when you lose your rocker panels, huge crack in your gas tank(I'd turn and gas would spill out, broke down and bought a new tank), and brake/tranny lines crack, all from rust. Nothing like driving a 23 year old car.
And my maxima's actually is pretty good shape underneith, considering its been in canada for all its life and has 165,000kms.
#72
Resurrecting an old thread. My oil cooler line looks like this, except worse:
Can I just splice in a long piece of heater hose and junk the metal line? Anybody know what diameter of hose to use?
Finkle
09-27-2015 09:53 PM
