why is my battery light and my brake light on?
Old 05-31-2010, 06:02 PM
BiZzL3's Avatar
ok so i was driveing home and i notice that my Brake light and my Battery light are both now on?... what does this mean and is there a way to reset the light's? i know on my 4th gen i did some thing like push the door button so many times then turn the car on..... any idea's?
BiZzL3 is offline
Old 05-31-2010, 06:28 PM
nismopc's Avatar
alternator and/or battery
nismopc is offline
Old 05-31-2010, 07:48 PM
soto2635's Avatar
2x on mine i had this same issue and i had to replace the battery and alternator
3x i had to get mine replaced as well
soto2635 is offline
Old 05-31-2010, 08:17 PM
nzelinsky's Avatar
sounds like alternator. It hasnt happened on my max but several other cars. Be careful you might get stranded
nzelinsky is offline
Old 05-31-2010, 08:21 PM
arcueda's Avatar
yup alternator most likely
had that problem
arcueda is offline
Old 05-31-2010, 08:28 PM
sanford7575's Avatar
why is my battery light and my brake light on? Reply to Thread
probably alternator.
get a volt meter and ck valtage of battery with and without engine on. should be arpund 13.5 and 12.5 respectively
sanford7575 is offline
Old 05-31-2010, 09:25 PM
Max_5gen's Avatar
Most likely - alternator and you might have less than 10 miles to go .
Max_5gen is offline
Old 06-01-2010, 10:53 AM
BiZzL3's Avatar
Thanks everyone, its all over..... i was driveing to work this morn and ALL my lights came on and ALL my gauges were jumpin, i got to work and DONE, lol put a new battery in it and i atleast got it home.........thanks again
BiZzL3 is offline
Old 06-01-2010, 11:26 AM
Nelsito65's Avatar
^^Not sure what you mean by "I got it to work and DONE", but this might not be the end of the problem. You should get that alternator checked before it ruins the new battery too, in case it is something you also need to replace.
Nelsito65 is offline
Old 06-01-2010, 11:51 AM
princeholiday's Avatar
my friend just found out her max brake and engine light came on too...I heard people not suggesting autozone alternators, what about advancedauto, and if not..what other suggestions?
princeholiday is offline
Old 06-01-2010, 12:02 PM
mandyfig's Avatar
You will damage your new battery of the issue is the the alternator. Did your battery supplier check if the alternator was charging sufficiently? And it was the battery which had an issue?
Battery issues are totally different from alternator issues. Your description is more of alternator problem.
Get the alternator tested pronto. If your alt is defective, your battery will last a few months only and you will be back in the same boat.
We (a lot of us) have been through your kind of symptoms.
mandyfig is offline
Old 06-01-2010, 12:16 PM
Nelsito65's Avatar
Brake and Service Engine lights can point to different problems by themselves. Brake light could be, among other things, as simple as a burnt brake bulb. Ask your friend to have the car scanned for codes too if the SES light has come on.
And by the way, I purchase most of my parts from Autozone, including my alternator, and I have had no issues with their parts. But I know some other members can't say the same.
Old 06-01-2010, 12:29 PM
Anywhere to have her have the alternator installed in brookyln, ny area besides stealership...thanks for the help...
Old 06-01-2010, 12:42 PM
Nelsito65's Avatar
I'll step aside for others to advise; I'm a couple of blocks away from there...
If anything fails try the local forums:
http://forums.maxima.org/northeastern-u-s-11/
Old 06-01-2010, 12:53 PM
mandyfig's Avatar
Mine's from advanceauto...can not complain, lifetime warranty.
mandyfig is offline
Old 06-01-2010, 06:00 PM
Max_5gen's Avatar
Oh, you'll understand one day . I think, he is on the right track - based on his symptoms alt was undercharging the battery so he could only go as far as the charge in the battery itself allowed him to. I also think his 'dead' battery is still good - just needs to be recharged, preferably out of the car. I don't think there's any other problem with the car.
Max_5gen is offline
Old 06-01-2010, 07:20 PM
Nelsito65's Avatar
Now I'm not sure I understand you. You "don't think there's any other problem with the car"? You mean the only problem was a dead battery?... but, the alt undercharging the battery is not a problem?... . I guess I'll understand one day...
Old 06-01-2010, 08:19 PM
Max_5gen's Avatar
I meant - no other problem besides bad alternator, there's nothing else to check there at the moment. I was also objecting to the idea that in his case alternator can possibly ruin new battery. I'd definitely check the voltage at 1k rpm after alt replacement of course.
Max_5gen is offline
Old 06-02-2010, 09:46 AM
mandyfig's Avatar
This is not related to this post but I have come to realize that auto shops (had a direct experience with PepBoys a long time ago), to be specific certain mechanics will diagnose a bad battery and will go ahead and sell you a battery. A few weeks later, you take it in because your NEW battery is limping along and then they say, it is the alternator.
It was the alternator from day 1.
Replacing an alternator is much harder than swapping a battery they can quickly send you on your way.
Just an observation. I have heard it too many times.
mandyfig is offline
Old 06-02-2010, 07:07 PM
Max_5gen's Avatar
Sadly but true... There's an option to actually check things around but they always take an easy route often at the owner's expense.
Max_5gen is offline
Old 07-02-2010, 05:39 PM
Rods03Max619's Avatar
to batt or alt
Rods03Max619 is offline
Old 07-02-2010, 08:45 PM
MR MAD MAX 2K's Avatar
my brake light came on today wen i started the car but went of later wen i was drivin what do that meen i hope not the altornator this car is becomeing a money pit i just put in a ac conpressor and thats not cheap
MR MAD MAX 2K is offline
Old 07-03-2010, 07:29 AM
Max_5gen's Avatar
Check level of your brake fluid. My definition of a 'money pit' is $1k/year when it's 8+ years old.. If it exceeds that then yes, you've got one.
Max_5gen is offline
Old 07-03-2010, 08:37 AM
sontakke's Avatar
I don't know about you but new car payment is in excess of $500 per month. Money pit is if your car needs $6000 per year in maintainance
sontakke is offline
Old 07-03-2010, 11:22 AM
Max_5gen's Avatar
At that rate almost anything fits definition of 'good, reliable car' . Seriously, I meant the money you actually paying for maintenance and was referring to the used ones, 6+ years old. At certain point any car requires more than 1k/year in maint+repairs. Some reach this limit earlier, some later. My 1993 SE so far still under the mark and 2k one has been probably around $800/year, including T1R summer tires and fluid/brakes changes. Over 10 years / 300k km I replaced 4 coils, starter, oxygen sensor, battery, ebrake, CV boots, ball joint, motor mounts, wheel bearing, rotors. I did all of that myself (ex bearing replacement) which helped to keep costs down as well as to avoid extra problems. I screwed up 2 sensors: MAF and ABS and was out for about $350 as a consequence, considering it price for education .
Max_5gen is offline
Old 07-04-2010, 07:38 PM
traffik's Avatar
Alternator repair
Yes she can take it to BYPerformance on cooper ave. @347-537-5975
traffik is offline
Old 09-01-2010, 10:00 AM
arima's Avatar
is my problem just brewing? I had the brake/battery light come on over a month ago. It came on over the weekend again. Does it stay on or does it just kind of stays on a few seconds? Both times it happened as i was parking the car. I've driven the car for the last 4days and nothing. Should i be worried.
arima is offline
Old 09-01-2010, 10:23 AM
Max_5gen's Avatar
If both lights were on you should be and check alternator soon if only brake light was on - check your brake fluid level instead.
Max_5gen is offline
Old 09-01-2010, 03:38 PM
arima's Avatar
both lights came on at the same time, but it was on less then 10second and then went away.
arima is offline
Old 09-01-2010, 07:03 PM
Nexus67's Avatar
Sounds like the beginning of the end. Would definitely check the alternator. When mine starting going, the light wasn't consistent, but the car finally did die (luckily I was within autoshop range and didn't have to go far).
Nexus67 is offline
Old 09-01-2010, 11:16 PM
BLACKKILA.GTR's Avatar
brake and battery light is an alty fail indication.... i just went through this and i had a performance alry on the car... make sure after u replace the alty that the battery is fullly charged
BLACKKILA.GTR is offline
Old 10-06-2010, 06:07 AM
vball_max's Avatar
Hey guys.....
I got the good old brake and battery lights this morning as I was driving around looking for parking.
I only drove a couple blocks with them on, then parked the car. My question is how far can one typically drive after the lights come on?
I have an appointment with my mechanic this afternoon and he is about 20-25 miles away, and I have to stop to pick up an alternator on the way. What do think my chances are of making it there without breaking down?
We can start a pool on whether I will make it or not and I will let you know the results tomorrow
vball_max is offline
Old 10-06-2010, 07:13 AM
stockmax's Avatar
Just curious, what does the brake light have to do with the alternator?
stockmax is offline
Old 10-06-2010, 07:41 AM
BlackMacks's Avatar
Originally Posted by vball_max
Hey guys.....
Vball, when my alternator went out, I literally had about 10-15 mins of run time, before the car shut off. Granted, I had the A/C on, radio on, etc., and hitting your brake lights sucks up a TON of juice. If you were able to head to your mechanics shop without ANY accessories on (headlights, wipers, etc.), and rarely using your brakes, you _might_ make it. My suggestion would be to bring a spare fully charged battery with you, to swap out if needed.
BlackMacks is offline
Old 10-06-2010, 08:29 AM
ColdRain's Avatar
just updating, this should be 14.5 with engine on and 12.5 with engine off at minimum.
ColdRain is offline
Old 10-06-2010, 08:30 AM
vball_max's Avatar
Thanks for the info. Since I posted, I added a battery to my order thinking the same thing. The parts store is only 4 miles away so I should make it there on time. Unfortunately I dont have any tools so I will have to buy a wrench there too. Do you know the size of the battery nuts? I believe its 10mm.
Old 10-06-2010, 08:58 AM
BlackMacks's Avatar
Yeah, a simple 10mm box/open wrench will take your battery terminals off.
Old 10-06-2010, 09:11 AM
vball_max's Avatar
great.....thanks! Wish me luck....i am heading out soon.....
I hope I make it and dont have to change the battery....its raining like a b!tch here today
Old 10-06-2010, 11:32 AM
Nelsito65's Avatar
The brake light alone, usually nothing; the brake and the battery lights is usually an indicator of a bad alternator. There are also other light combinations that point to a bad alternator.
Old 10-06-2010, 02:14 PM
sontakke's Avatar
Was there ever even any indication of alternator going before both lights went solid? Were they flickering once in a while in the past? How many miles?
I am wondering if I should just proactively change the alternator.
- Vikas
sontakke is offline
Quick Reply: why is my battery light and my brake light on?
