Idler pulley tension effecting alternator? - Maxima Forums
Thread Tools Search this Thread
Old 04-25-2012, 01:11 AM   #1
Alright, so my alternator started making a hellacious about a month ago. I replaced that alternator with a rebuilt one and the noise went away.
I thought the problem was fixed because the noise had temporarily gone away, but it's been about a week and the same alternator whining noise is starting to come back.
I'm wondering if there's a certain torque spec or something on the idler tensioner that's causing the drive belt to effect the alternator (i.e being too tight or loose effecting rotations) Or maybe I just happened to get an alternator that was on it's way out?
Maybe it's a faulty idler pulley?
Any input would be helpful, hopefully I can finally stop this noise, I might post a video later on if it needs to be specified.
Thanks alot guys
-Spence'
Spence is offline   Reply With Quote
Old 04-25-2012, 01:42 AM   #2
Is it making the same noise at all rpms? or is it just at idle, or under load, etc.?
My 240sx did that after changing the alternator on it, but I also changed the belt, and the belt was a half inch too large and wouldn't tension properly. I ditched that belt (that I got from Pep Boys), and got the proper length one from AutoZone, tensioned it up and there was no more noise after that. But it wouldn't make any noise at idle or below about 2,500-3,000 rpms, then it would whine.
In fact, several people asked me if my 240 was supercharged when I was having that issue. I, of course, just told them yes.
dfj240 is offline   Reply With Quote
Old 04-25-2012, 05:35 AM   #3
"I'm just sayin'..."
nelledge's Avatar
Check the belt for wear and follow the specs below for belt deflection.
nelledge is offline   Reply With Quote
Old 04-25-2012, 07:40 AM   #4
dot dot dot ...
NmexMAX's Avatar
Quote:
I should sticky this.
NmexMAX is offline   Reply With Quote
Old 04-25-2012, 09:59 AM   #5
Haha, at high speeds it does kinda sound like a supercharger. But in fact yes, it does make the whine at all rpms including idling.
I'm almost tempted to buy a belt for max's without AC and just remove my compressor seeing as how I don't have AC anyways.
And nelledge that's a great diagram. Answers my torque spec question.
If I don't get a torque wrench that can get down to that nut for the pulley does anyone know a rule of thumb how tight I should go with the tensioner bolt?
Old 04-25-2012, 12:26 PM   #6
nelledge's Avatar
Quote:
I agree. It is amazing how many car enthusiasts I talk to that don't understand the importance of the correct belt deflection.
Old 04-25-2012, 12:51 PM   #7
Well, I find it amazing how many people's knowledge about cars ends after putting key in the ignition switch and starting it. And they don't even know that ignition switch is the name of the "thing" that they put the key in.
DennisMik is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Bringing my 1996 Maxima back to the road after 8 years. My Coffee New Member Introductions 14 12-17-2016 01:40 PM
for 2k2 2k3 owners, if you need a new MAF... TallTom 5th Generation Maxima (2000-2003) 41 04-30-2016 12:39 PM
Mobil 1 0W40 is some good stuff mclasser 5th Generation Maxima (2000-2003) 16 02-19-2016 05:45 PM
Dimmer Switch Doesn't Work? gavin68 5th Generation Maxima (2000-2003) 4 09-28-2015 07:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
