5th Gen: What did you do to your 5th Gen today?
Old 02-09-2016, 05:08 PM
  #2401
Donkeypunch's Avatar
Did you take it out just to reseal it?
Donkeypunch is offline
Old 02-09-2016, 05:44 PM
  #2402
nestorlugo's Avatar
Nah , rod knock!
nestorlugo is offline
Old 02-09-2016, 06:54 PM
  #2403
cornholio's Avatar
Originally Posted by nestorlugo
Nah , rod knock!
so what are you putting back in?
cornholio is offline
Old 02-09-2016, 07:30 PM
  #2404
Bad *** Newb
Child_uv_KoRn's Avatar
Finally I get a glimpse of the oil leak!!!
In a noob moment I forgot to break the crank bolt!!
Now I need to figure out hit to do that
Damn crescent seal always goes before the main, but it doesn't leak much.
Buy a nice impact. They're invaluable.
Child_uv_KoRn is offline
Old 02-09-2016, 08:23 PM
  #2405
nestorlugo's Avatar
Perhaps down the road I will, for now I found a 10 year old thread (and like a newb i almost posted )
but looks like I'll be trying the chain wrench and brkr/chtr bar method if that don't work tire shop if that don't work than I'm down the road at that point...
Old 02-09-2016, 09:10 PM
  #2406
Bad *** Newb
You can jam a big crowbar into the flywheel and use a breaker bar on the bolt. Two people job, but it works.
Old 02-11-2016, 02:06 PM
  #2407
losifanatic's Avatar
My girlfriend is freaking amazing. This is my Christmas and Valentine present. They showed up today!!!!
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-20160211_165818.jpg
losifanatic is offline
Old 02-11-2016, 02:09 PM
  #2408
Mattx's Avatar
You my friend may have a keeper. Does she cook and clean?
Mattx is offline
Old 02-11-2016, 02:22 PM
  #2409
nestorlugo's Avatar
Another 3.0 it has 101k
I'm a broke boi'. I did however find a 08 alitima engine with a cracked timing cover for $350 I plan on buying and building slowly,
Old 02-11-2016, 02:28 PM
  #2410
I'm the cook and the maid. Lol
Old 02-11-2016, 04:04 PM
  #2411
Mattx's Avatar
Uh oh. Is she well compensated by her employer?? I may have to rescind my previous post I'll await your answer.
Mattx is offline
Old 02-11-2016, 10:23 PM
  #2412
Bad *** Newb
I can has? I need more car parts LOL
Old 02-13-2016, 08:42 PM
  #2413
nestorlugo's Avatar
Got her a valentines day present from courtesyparts...
Old 02-14-2016, 10:29 AM
  #2414
23° out and attacking the header install. Dang it's cold. Inside to warm up
Old 02-14-2016, 12:57 PM
  #2415
Mattx's Avatar
Don't know if you did but I'd say the best way is yank the fans , radiator, and the crossmember. It makes it pretty easy once that stuffs out of your way. Probably could leave rad but fans help.
Mattx is offline
Old 02-15-2016, 02:15 PM
  #2416
Just an fyi. This job SUCKS doing on jack stands expecially on a car this old. It was a direct fit so I didn't have to grind anything off lIke I have read. The rear 02 sensor doesn't fit. Have to relocate it. That's all I have left to do to finish the headers
I have off on Thursday so I am hoping to do my motor mounts and lightweight crank pully.
Old 02-16-2016, 07:26 AM
  #2417
Mattx's Avatar
Just an fyi. This job SUCKS doing on jack stands expecially on a car this old. It was a direct fit so I didn't have to grind anything off lIke I have read. The rear 02 sensor doesn't fit. Have to relocate it. That's all I have left to do to finish the headers I have off on Thursday so I am hoping to do my motor mounts and lightweight crank pully.
I'd skip the crank pulley. I've read some not so good things about them. Not to mention no gains. Also possibility of throwing the balance out of the motor.
Mattx is offline
Old 02-16-2016, 10:33 AM
  #2418
I thought the maxima was internally ballanced? Will have to check into that. Thank you for the heads up!
Old 02-16-2016, 11:10 AM
  #2419
Mattx's Avatar
It just so happens last night another org member and I were texting about the same exact thing so I did a quick search and found a lot of negative on it.
Mattx is offline
Old 02-16-2016, 02:03 PM
  #2420
Bad *** Newb
It's a myth just like engines need back-pressure. Too many ****** that own(ed) old engines. VQs are internally balanced very well.
Our crank pulley is not a harmonic balancer or crank vibration dampener. End of story.
If anything, the stock pulley causes more bearing wear b/c it's less balanced than a precision made piece of billet aluminum (not to mention heavy as **** throwing it's mass around).
Also, stock pulley goes bad b/c the idiots still made it a two piece with a layer of rubber in the middle (for belt noises? nissan is so dumb). So, have fun with increased bearing wear when it starts to wobble...even when you don't notice it.
And no gains is a lie! Stock pulley weighs 12 lbs. UDP is almost 1, iirc. That translates into an 8 whp gain with a little help from 20% underdrive.
The ONLY issue that you can face is the crank seal wearing and wearing a groove in the pulley if it doesn't have a steel sleeve. But this takes quite a lot of miles before it's even going to leak. edit: for some reason I thought the UR pulleys didn't have the sleeve, they do (found one in the garage).
I'm sure everyone would appreciate it FUD isn't spread around like facts.
I have FOUR UDPs on my cars. One is on the VG and it's not balanced as well as the VQ, yet, in the history of 300ZXs there's never been a problem from it. Imagine that.
Old 02-16-2016, 04:03 PM
  #2421
I have been searching and everything I read for the vq motor is that the lightweight crank pully won't hurt a thing
Old 02-16-2016, 07:34 PM
  #2422
Mattx's Avatar
https://www.dropbox.com/s/gipjzionz0...06.17.png?dl=0
Here you go from a well know well respected org member from a time back when there were a lot more on here. Not one guy trying to shove his point across to everyone. I can bring you a lot more from this very org that say the same thing. So don't dare say that I'm spreading false info intentionally I resent it. This is all info that I learned on this site by reading. You have a very annoying habit of jumping on people and acting like a complete know it all. It's extremely annoying. I may be wrong I'm just putting info out there that I read on this site. If you want more quotes I'll provide them. But your tough guy over the top routine is very lame you ought to tone it down a couple notches.
Mattx is offline
Old 02-16-2016, 07:36 PM
  #2423
Mattx's Avatar
^the above was in reference to childish of the corn hole.
Mattx is offline
Old 02-16-2016, 07:55 PM
  #2424
Bad *** Newb
I'm sorry, how does installing a lighter, more balanced pulley, somehow change the physics of how it operates in a negative way?
Engines need to be very balanced when making big power/high RPMs, yes... and your point is? The UDP is better balanced than a STAMPED HUNK OF STEEL with a few holes drilled in it (sometimes no holes, must be "good enough" then).
The VQ is already internally balanced from the factory. The crank pulley is NOT AN ENGINE DAMPER OR HARMONIC BALANCER which is why nealoc's point isn't applicable (I swear I said this before). And top it off, the stock pulley fails and becomes more and more imbalanced with age until it splits in two.
I do try to be nice (I'm not nice, so there ya go), but this kind of crap gets really old.
You might as well never think about a lightweight flywheel or different clutch. By this logic, then those will cause balancing issues and ruin the motor. Another huge, heavy ,mass-produced, piece of steel is bolted on the other end of the engine...I'm sure it's perfectly balanced and superior to a light weight flywheel...
Also, take a look at other imports. Many come with a solid pulley from the factory, because they are internally balanced as well.
Old 02-17-2016, 08:40 AM
  #2425
Mattx's Avatar
You missed my point totally and I didn't expect you to get it anyhow.
Mattx is offline
Old 02-17-2016, 10:42 PM
  #2426
Bad *** Newb
Oh, I got it. Being offended is more important than facts.
Go on facebook and whine like rest of the SJWs.
Old 02-18-2016, 08:55 AM
  #2427
Mattx's Avatar
Oh, I got it. Being offended is more important than facts. Go on facebook and whine like rest of the SJWs.
Still missing it try again.
Mattx is offline
Old 02-18-2016, 09:09 AM
  #2428
dot dot dot ...
NmexMAX's Avatar
Dog too? Seems like a cool little dude.
NmexMAX is offline
Old 02-18-2016, 09:52 AM
  #2429
Dog was a Christmas present from my kids about 3 years ago. Awesome dog couldn't of asked for a better one. She is a beagle and blue tic hound mix oh and spoiled rotten.
Old 02-20-2016, 05:59 AM
  #2430
Got my rims put on yesterday. Had to work on my old 2k maxima so I haven't had time to finish mine. Still need to relocate 02 sensor and install the lightened crank pully
Old 02-20-2016, 09:27 PM
  #2431
a33_ridah's Avatar
^which pulley did you end up going with? 2jracing? or another. I may have missed it as well but also what headers you using
a33_ridah is offline
Old 02-21-2016, 12:13 PM
  #2432
Obx headers and ralco pully(oem size )
Old 02-21-2016, 08:35 PM
  #2433
Itz Shak's Avatar
Had Vqmaxman fix my power steering hose. Major difference in the way she drives now
Itz Shak is offline
Old 02-29-2016, 06:55 PM
  #2434
nestorlugo's Avatar
Got the side pieces for the front lip repainted,center piece had a clear coat run so dude had to fix it..Name:  20160229_202522_zpstzorrwrc.jpg
Old 03-04-2016, 07:07 PM
  #2435
Got the shifter cable mount replaced today. Painted the front calipers again ( dropped the calipers when I was doing the wheel bearings and it chipped some of the paint off)
Replacing the fill hose and high pressure hose for the power steering tomorrow and I think I will put the rz crank pully on and new belts
Old 03-05-2016, 02:23 PM
  #2436
Put on new belts and the lightweight crank pulley. Replaced the power steering hoses and replaced the oil cooler line.
The lightweight pulley is 4 pounds lighter
Also found out I need a new cv shaft on the passenger side. 2 of the 3 mounting bolts are gone and where they thead in is broken. Don't know how that would happen????
The stillen front lip is supposed to be finished being painted on Monday. Also have a guy the said he could weld the new o2 bung in. Hope to have that next weekend.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-20160305_131239.jpg   5th Gen: What did you do to your 5th Gen today?-20160305_131227.jpg
Old 03-05-2016, 02:40 PM
  #2437
nestorlugo's Avatar
Oooooooweeee! Yo' boi pulled out the dope man scale!
I need to get me one of those
Ps. The pulley that is!
Old 03-05-2016, 05:57 PM
  #2438
Got the cv shafts ordered this evening.
Old 03-06-2016, 09:08 PM
  #2439
Bad *** Newb
Your pulley needs to go on a diet
Old 03-12-2016, 12:08 AM
  #2440
Itz Shak's Avatar
Got rid of that stock B-pipe and got a custom 3" exhaust with Megan racing muffler
Megan Racing
Itz Shak is offline
Quick Reply: 5th Gen: What did you do to your 5th Gen today?
