5th Gen: What did you do to your 5th Gen today?
Old 08-19-2016, 08:51 PM
  #2721
maximatech12's Avatar
removed entire air cleaner assembly, removed Air temperature sensor + MAF sensor. Submerged in soapy water cleaned.
Removing throttle + Plenum for VCG's. Gotta check Knock sensor had a P0325 flash but went out.
I have 2Mega ohms slot is this enough?
maximatech12 is offline
Old 08-21-2016, 08:03 AM
  #2722
Canadianmaxownr's Avatar
Today i tinted my tails with some NiteShade and some clear coat! A cheap easy mod that gives a heck of an improvement!
Also, i painted my front grill and honks!
Next up would be my fog's holes painted black, or should I put lights in em?
Also tinting my back window is a must!
Canadianmaxownr is offline
Old 08-21-2016, 11:44 AM
  #2723
Sam Maxima's Avatar
Put fogs on it-the 5th gens looks incomplete without the fogs IMO
Sam Maxima is offline
Old 08-21-2016, 11:47 AM
  #2724
Sam Maxima's Avatar
Took my 03 for a drive and started to running bad(skipping/sputtering) got back home got my Snap on scanner and found the Cyl#5 has misfire,so I just change the coil and went back for a drive and no more sputtering and runs smooth.I didn't drive the car about 10-13 days as I just got me a G35S and now my Maxima just sit in my driveway.
Old 08-21-2016, 11:50 AM
  #2725
Was thinking about yellow one! Cause jdm yo!
Also i would like to put a catback on it, any cheap idea that dont sound like a fart can neither wakes my neighbors up!
Old 08-21-2016, 11:55 AM
  #2726
Sam Maxima's Avatar
On my Maximas I gutted the cats(all 3) and that's actually it's loud enough for me.As on the cat back I don't have any idea as which would be nice,I have the HKS turbo back on my 240sx and I love it,but it's turbo'd so with the NA it will sound different
Old 08-21-2016, 12:05 PM
  #2727
On the vq35 a cat back really does sound great cause of the v6 but im not sure if cheap ebay one's Will sound crappy or not... :/
Old 08-21-2016, 12:09 PM
  #2728
Sam Maxima's Avatar
Yes they do,I was just afraid if they were going to be too loud as my car was and is my daily
Old 08-21-2016, 12:23 PM
  #2729
Thats my concern! I dont feel confortable with gutting or removing the cats tho... if i do something it will be replacing it with a highflow cat! But for now i think à catback would be fine! Just need to know if the 150$ one's arent too loud!
Old 08-21-2016, 12:26 PM
  #2730
Bad *** Newb
Child_uv_KoRn's Avatar
Cats barely do **** for noise reduction. Highflow cat is as much as a waste of money as precats.
Child_uv_KoRn is offline
Old 08-21-2016, 12:27 PM
  #2731
Ikr... i still dont want to gutt or eliminate em! Just want to have a better exhaust flow! But for now, i want more sound
Old 08-21-2016, 09:02 PM
  #2732
manilakid3's Avatar
My radiator was leaking the other day. Ordered a new one from Amazon and also the thermostat. Now she's back on the road. lol
manilakid3 is offline
Old 08-21-2016, 09:37 PM
  #2733
Itz Shak's Avatar
Just installed and routed the wideband into the cabin. Just need to find a good spot for it now..
https://goo.gl/photos/w9Cb745cDgTQ7k9TA
Those who are good with tuning feel free to drop a comment/advice
Itz Shak is offline
Old 08-22-2016, 10:02 AM
  #2734
Donkeypunch's Avatar
Looks good. That's the stock afr?
Donkeypunch is offline
Old 08-22-2016, 02:33 PM
  #2735
Bad *** Newb
If you have a 3.5, then you don't have a choice unless your choice is replacing the engine or buying another car.
Old 08-22-2016, 02:46 PM
  #2736
What you mean?
Old 08-22-2016, 08:00 PM
  #2737
I think he means the cats supposedly break up and get sucked up by the exhaust, destroy the engine.
Old 08-22-2016, 08:03 PM
  #2738
Ohh yeah thats True! Mine are still good tho so if i change em it will be for a highflow cat and delete de the precats!
Old 08-23-2016, 03:08 PM
  #2739
Itz Shak's Avatar
Yessur.. Looks like there wont be much modifying it eh?
Itz Shak is offline
Old 08-24-2016, 12:16 AM
  #2740
Maybe.
You can try to squeeze out alittle hp but paying for dyno time. Really worth it?
I don't think so. :P
What piggy back u have?
Old 08-24-2016, 07:08 AM
  #2741
Today i found out my car was realy made in japan
Old 08-24-2016, 03:21 PM
  #2742
Bad *** Newb
Well, duh, the ones assembled in NA are junk *looks at sentra* lol
Old 08-24-2016, 04:21 PM
  #2743
Derrick2k2SE's Avatar
If the first character in the VIN is a "J" it's assembled in Japan.
Derrick2k2SE is offline
Old 08-24-2016, 04:23 PM
  #2744
I just never looked closely at that plate before! But the "made in japan" made it pretty obvious!
Old 08-24-2016, 08:51 PM
  #2745
DennisMik's Avatar
According to the VIN, the plant where it was assembled is Oppama, Japan.
DennisMik is offline
Old 08-25-2016, 12:27 PM
  #2746
Reallyslowrio's Avatar
Replaced my Bank 2, sensor 1 O2 sensor last night. One of the easiest O2 changes I've ever done.
Goodbye cel, at least for now.
Reallyslowrio is offline
Old 08-25-2016, 11:40 PM
  #2747
Cotozic's Avatar
Car was running lean for a while. I hadn't driven it hard since I had been dealing with replacing broken parts, like my Powersteering hose and miscellanious annoyances, such as the IC piping rubbing on my shift cable and snapping apart. The A/F was acceptable at crusing so I never really noticed until I would occassionally hit boost at 4k. Worked for a week tracing down the problem. Wasn't the FPR, but it was this little hose that connects the fuel pump to the fuel pump assembly. Super easy fix. Love opening that gas tank. Having no evap system leads to the cabin smelling up, and it was super bad when this hose was loose/torn because it would just spray fuel onto the fuel assembly lid. So much awesome.
Car is running great now. Actually getting to race around and feel the rush. Onto new wheels.
Cotozic is offline
Old 08-26-2016, 09:36 AM
  #2748
TSelanne's Avatar
wow how'd you ever diagnose that?
TSelanne is offline
Old 08-27-2016, 10:09 AM
  #2749
losifanatic's Avatar
Washed, waxed, and cleaned the inside. Adjusted tire pressure from 35psi to 25psi
So raced a 2013 turbo malibu and a fully modded 2008 Hyundai Tiburon(my neighbors) Well it wasn't even a race really. The tiburon wasn't even remotely close and he was the one talking most the crap. They guy in the malibu was about 5 cars or so back to 120.
Love living down a mile long private straight away!!!!!
Girl friend and I are almost finished with her car . So hopefully we will be racing tonight
losifanatic is offline
Old 08-27-2016, 10:41 PM
  #2750
Cotozic's Avatar
A/F ratio was showing lean at higher throttle. Smell of gas was really bad inside too. I pulled the backseat off and saw some gas had absorbed into the seat and there was gas on the top of the cover.
I talked to Moncef at AdminTuning for some help, and we wanted to narrow down the problem, and decided to swap a different FPR to see if that fixed it, and no change. I should've checked in the gas tank first. I noticed I would lose fuel pressure after driving, and that it was constantly low regardless. I also struggled to get fuel when accelerating at all with a low tank. I was really almost certain it was the pump.
I should've opened the gas tank earlier. I had thought the pump was not getting a good connection, and Cef even suggested it later. Feel stupid for not checking to begin with.
Cotozic is offline
Old 08-28-2016, 06:42 AM
  #2751
Itz Shak's Avatar
Video?
Itz Shak is offline
Old 08-28-2016, 06:46 AM
  #2752
Itz Shak's Avatar
@Cotozic How lean?
Itz Shak is offline
Old 08-29-2016, 11:01 PM
  #2753
Cotozic's Avatar
Originally Posted by Itz Shak
@Cotozic How lean?
Essentially it wouldn't go any richer than 14 at any point with my foot on the gas. If I really stepped on the gas, it would run down to 14, and as the revs climbed and hit boost, it would jump to around 15-16. Now when I hit boost, it jumps to 12 to 10. It's tuned richer, and that's how I'd rather it be.
Cotozic is offline
Old 08-31-2016, 04:02 PM
  #2754
Itz Shak's Avatar
Yeah that sounds much better @Cotozic
Anyone know what happened to NMexmax? Hasn't been active
Itz Shak is offline
Old 09-03-2016, 09:03 PM
  #2755
sebastian2041's Avatar
Well today i put new wheels and lowered the exhaust mount since my it was banging it... car ks looking monster trucky because i dont have coil over wrenches but i will order some and drop it
sebastian2041 is offline
Old 09-08-2016, 06:37 AM
  #2756
Had a bad clunk in the front end since I got the car a few months ago; turns out the subframe was about to fall out of the damn car. One missing bolt and the other was only hanging on by 2 threads. 2 window welded motor mounts and a junkyard bolt solved so many issues I was having.
While I was under there, a friend gave me a test pipe from his 240SX. Spent $6 on gaskets but the junkyard gave me $15 for the old cat. Technically made money on this mod. (for those wondering, there was zero sound difference)
Old 09-13-2016, 08:04 AM
  #2757
HerBlue2kSE's Avatar
Finally fixed the aftermarket radio reception problem - reversed the factory connector in the aftermarket antenna adapter and I now get HD radio stations. I am quite impressed with the sound of the Bose system when paired with the Kenwood DPX-791BH.
HerBlue2kSE is offline
Old 09-15-2016, 11:22 PM
  #2758
Mike Jenne's Avatar
Replaced a leaking power steering hose with the help of lots of previous posters to the forum here. Now to go update that thread with a tip I don't think has been shared before, but helped me out.
MJ
Mike Jenne is offline
Old 09-16-2016, 03:05 PM
  #2759
4thgenmax97's Avatar
Dome LED
Passenger Courtesy LED
Driver Courtesy LED
Reverse LEDs
License Plate LEDs
Add White LEDs:
4thgenmax97 is offline
Old 09-20-2016, 09:07 PM
  #2760
pixelporsche's Avatar
Research. What's a reputable company in the NW to buy a low mileage VQ30DE from? :>
pixelporsche is offline
Quick Reply: 5th Gen: What did you do to your 5th Gen today?
