At WOT it only revs at 6,000 rpm. It's redline is at 6,600
Old 05-07-2014, 09:29 AM
bizzy9221's Avatar
5.5 gen only revs to 6,000 at WOT?
At full throttle it only revs to 6,000? Redline is at 6,600 but will only reach 6,000 slowly and i feel a slight power loss up top for some reason. Any reason for this?
bizzy9221 is offline
Old 05-07-2014, 09:56 AM
bizzy9221's Avatar
At WOT it only revs at 6,000 rpm. It's redline is at 6,600. It used to rev at 6,200 but now it only stops at 6,000 with a slight loss of power at the same time. Low end power is good but top end feels sluggish now. Any reason for this?
Old 05-07-2014, 10:22 AM
nsnrider's Avatar
try cleaning the mass air flow sensor with appropriate cleaner. if it doesn't work, might need to replace it.
nsnrider is offline
Old 05-07-2014, 10:36 AM
bizzy9221's Avatar
What is the proper way to clean it? I tried taking it out once but the two screws holding it down are rusted.
Old 05-07-2014, 10:38 AM
dot dot dot ...
NmexMAX's Avatar
http://forums.maxima.org/5th-generat...10-w-pics.html
NmexMAX is offline
Old 05-07-2014, 11:05 AM
bizzy9221's Avatar
Thanks. Although I lost the straw
Old 05-07-2014, 05:10 PM
dfj240's Avatar
Check cats, including precats. Also could be MAFS.
dfj240 is offline
Old 07-31-2014, 06:33 AM
bizzy9221's Avatar
I figured out it was the cats they were all clogged and now gutted
Old 07-31-2014, 06:52 AM
dot dot dot ...
NmexMAX's Avatar
So ... now you rev to 6600? Never heard of such a problem but theoretically I guess it makes sense.
NmexMAX is offline
Old 07-31-2014, 07:01 AM
bizzy9221's Avatar
Yeah other then the fact i heard its common for first gear to short shift. But as for over all acceleration it's all there and more. I even replaced the MAF for the hell of it
Old 07-31-2014, 08:27 AM
colt149's Avatar
Wot
[[c
olor="black"]i]i have read in one of the thread that gle and gxe 5th gen maxima have rev limiter done by nissan due to safety issue. The front stabilizer bar is only 22mm and the coil spring and suspension are not sport tuned.
Gxe havee p215/55hr16 with overall height of 56.3
gle have p215/55hr17 with overall height of 57.1
se model of 5th gen maxima does not have a rev limiter with thicker front stabilizer bar 23mm, sport tuned suspension-higher rear spring rate with performance tire p225/50vr17, overall height is 56.7.
[/i]
[/COLOR]
colt149 is offline
Old 07-31-2014, 08:50 AM
dot dot dot ...
NmexMAX's Avatar
All Maximas have rev limiters, no matter the year, trim or tranny.
NmexMAX is offline
Old 07-31-2014, 08:56 AM
dwapenyi's Avatar
Yeah...must have been a typo for speed limiter.
The inaccuracy of the OEM analog tach becomes painfully obvious when you watch a youtube video of a Maxima running hard to redline with one of those digital fuel controllers set to display rpms.
dwapenyi is offline
Old 07-31-2014, 08:59 AM
dwapenyi's Avatar
How did the pre-cats look?
dwapenyi is offline
Old 07-31-2014, 10:55 AM
bizzy9221's Avatar
Bank 2 pre cat was all in crumbles. Bank 1 had the whole broken piece of honey comb hanging out the outside of the pipe like it was trying to pinch a ****.
Old 07-31-2014, 02:57 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Where's all the nonbelievers, now?
I hope they didn't damage your cylinder walls or rings.
Make sure to gut the rear cat. It's probably full of the debris and still choking the engine.
Child_uv_KoRn is offline
Old 07-31-2014, 03:14 PM
100% chingon
clive's Avatar
Won't gutting the precats throw a code?
clive is offline
Old 07-31-2014, 03:42 PM
dot dot dot ...
NmexMAX's Avatar
Seems like antifoulers do the trick. No need to mess with wiring with sims thse days.
I've yet to have a secondary code and I've had headers for 9 years/110k miles.
NmexMAX is offline
hcarter1112
42
07-18-2022 03:35 PM
salty318
09-29-2015 01:21 PM
salty318
09-28-2015 07:22 PM
soybeanz
09-25-2015 10:46 AM
Quick Reply: At WOT it only revs at 6,000 rpm. It's redline is at 6,600
