Nexus 7 Install with Steering Wheel Control (Replaces Headunit Completely)
#45
#46
It's possible you don't have one. It would be next to the MODE button on the left-hand side of the steering wheel...
Here is an '01 steering wheel w/o the TRIP button. Note the absence of the button and the second LCD on the tachometer...
#47
Yeah, I don't have one, what else can I check?
#49
i would check the wiring diagram for your 5th gen or search for a write up for making the steering controls work with your year maxima. i suspect that you need to ground the steering buttons (in an 02 it's the brown wire). the "trip" button was just a simple test.
#50
Which wire should I ground from?
#51
Take a look at the steering wheel portion of this write up...
https://maxima.org/forums/audio-elec...ng-colors.html
#52
#54
Yes, if this helps. I can activate the button function with a grounded wire (if one end is connected to the chassis and I touch the open end to the programmed button, it will activate. However it still will not work with the physical steering wheel buttons
#55
Dear friends I hope that you can help me out, I'm making basically the exact same setup but I have a few doubts.
The first being, the Alpine amp must receive a 12V power, but from my car cable harness I only have one 12V cable that is supposed to be soldered to the pin of the USB car charger, so how do I provide the current to the amp?
Thank you so much,
Roberto
Thank you so much,
Roberto
trasmadean
02-01-2017 08:20 PM
MikesChevelle
08-06-2015 11:36 AM
